 Post subject: How to create image on internal memory of Samung GT-S5360
PostPosted: August 6th, 2012, 9:56
Dear All,
Is there any way to obtain an image from a Samsung GT-S5360 internal memory running Android OS .
I must search for deleted data that have been stored in the internal memory.
Any suggestions would be greatly appreciated!
Thank you.
 Post subject: Re: How to create image on internal memory of Samung GT-S536
PostPosted: August 6th, 2012, 14:23
Yes there are dr forensics tools but they cost anywhere between 8-10 thousand pounds or upwards http://www.cellebrite.com/mobile-forens ... ducts.html
Realistically if your looking for free to going on cheap then your going to be out of luck unless someone else knows a way? Your other option is to see what dr companies have the tools to do this for you but it would be at a cost
Loki
PostPosted: October 22nd, 2012, 2:49
http://www.anythingbutipod.com/forum/sh ... hp?t=12426
Best tricks for it.
PostPosted: October 22nd, 2012, 2:52
WMP 10 and 11 come with MTP drivers which take precedence over MSC. Unistalling WMP 10 (restoring 9) should remove the MTP drivers. If however, you want to keep WMP 10, it's possible to uninstall just the MTP drivers (i.e, WMP Portable Device Support). Standard disclaimers ... backup ... system restore ... blah ... risk ... blah
run "RunDll32 advpack.dll,LaunchINFSection %windir%\inf\WPD10.inf,DefaultUninstall"
this is the uninstall for the WMP Portable Device Support, it leaves a few things behind which are removed in steps 3-5
reboot
delete folders:
"C:\WINDOWS\RegisteredPackages\{981FB688-E76B-4246-987B-92083185B90A}
"C:\WINDOWS\RegisteredPackages\{981FB688-E76B-4246-987B-92083185B90A}$BACKUP$"
delete files:
"C:\WINDOWS\system32\drivers\wpdusb.sys"
"C:\WINDOWS\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WPD10.CAT"
delete registry key:
"HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servi ces\WpdUsb"
plug it in, if drives don't show up (this will happen if you've already used it in MTP mode)
go to device manager (check View->show hidden devices, just in case)
locate the Sansa device, it should have the yellow exclamation on it
uninstall it, through context menu
unplug, plug back in
now it should be installed as an MSC device and two removable drives will show up
Users browsing this forum: HannsGruber and 121 guests
