Bohack wrote:
Guys... I've gotta say that I'm pretty disappointed in this forum.
That's a shame, but this sometimes happens when someone has unrealistic expectations.
Bohack wrote:
All I've gotten was "bring it to a professional, bring it to a professional..." Which I take is the purpose of this forum to solicit business for yourselves.
I'm certainly not soliciting work for anyone, and I don't care what you do with your disk, so no it's not the purpose of the forum.
However when we thought you wanted to recover your data, you received the correct advice that this issue is outside of the scope of successful DIY in almost every case. It would be irresponsible
not to advise you to use a DR professional in that situation, if your data is important (as we first thought)! You even said:
Bohack wrote:
Both drive mean nothing to be [me?]... The data of course is a different story. (my bold and assuming "be" should be "me")
So due to the part you wrote, which I put in bold, then of course we thought that the data was important to you!
For the benefit of other new readers of the forum, even though you don't like the advice that you received, that doesn't change how correct it was, for the best chance of recovering your data - all IMHO, of course. If you had clearly said at the beginning "this data is not worth enough to be worth using the services of a DR professional", then that would have been different, but wouldn't have changed your liklihood of success doing DIY, unfortunately. Good luck with whatever you decide to do.
[Edited to add: This thread explains the general limits of DIY, and why your reaction is not surprising:
diy-what-the-big-deal-t12671.html"There are hundreds of other examples where the only answer could be "send the drive to a data recovery company". In these cases people get the best advise - visit a data recovery specialist, and in return we often see aggression." ]
