 Post subject: WD3200KS safe mode - only spins with Data Lifeguard Diag.
PostPosted: September 21st, 2012, 9:03
I've been reading several topics on this forum and probably reached to the conclusion that some firmware area of my WD3200KS-00PFB0 became damaged. Some years ago, I was playing with some HDD tools and the disk stopped spinning up on the boot by itself. It can only be put to work if I first execute Data Lifeguard Diagnostics and data can be properly accessed.
I guess that flashing a memory could be managed: I could put an Arduino or a Bus Pirate to work on this area.
Can you guys help me clarify what might be going on with this particular disk?
 Post subject: Re: WD3200KS safe mode - only spins with Data Lifeguard Diag
PostPosted: September 21st, 2012, 9:22
Could search power up in standby.
WD call it PM2
Search for HDAT2 software
Loki
PostPosted: September 21st, 2012, 9:37
HDAT2
http://www.hdat2.com/hdat2_faq.html#q19
Loki
PostPosted: September 21st, 2012, 10:40
Also have a look at guru's post (4th one down) & script for MHDD
wd5000aavs-pm2-puis-activated-unable-revert-t19107-20.html?hilit=mhdd%20script%20PUIS
Loki
Users browsing this forum: tomZZ and 104 guests
