Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29, 30 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: October 8th, 2012, 12:01
nyunyika0 ALL the information you need is already in this 27 page thread so I suggest you start reading from post # 1 forward many examples it is not an EASY task to perform it takes work on your end many hours to work this out.
PostPosted: October 14th, 2012, 12:06
SAjunky wrote:
paranoid wrote:
I had this on my old toshiba (not quite old but now got a new pc) , i didnt set any pass on my toshiba but when i installed the hdd in the new pc it asks for a password.
The easiest way is to put it back and look in the BIOS setup whether is there any security features enabled (including setup password). Disable all and I think your hard drive will be freed. Otherwise read this thread or spend more time searching net (it might be not worth though).
But i dont have that laptop anymore , i just know it was a toshiba satellite.
PostPosted: October 14th, 2012, 13:13
guys i have 2 hard drive that are locked. I have the 22.bin files(remove the txt extension). Can someone help me get the passwords for these 2 hard drives.
thanks in advance.
22_1.BIN.txt [512 Bytes]
Downloaded 1019 times
PostPosted: October 14th, 2012, 13:14
Here's the other one.
thanks.
22_2.BIN.txt [512 Bytes]
Downloaded 1052 times
PostPosted: October 14th, 2012, 13:55
iplayball, ALL the information you need is already in this 27 page thread so I suggest you start reading from post # 1 forward many examples it is not an EASY task to perform it takes work on your end many hours to work this out.
PostPosted: October 14th, 2012, 23:26
yes i know, i spent hours already and could not figure it out. i will re-read the posts.
PostPosted: October 15th, 2012, 3:02
@iplayball
You have done the harder part and dumped the modules correctly so its just the easy bit now!
By the way they don't look locked to me but if you don't care about the data then use the "master password" which is intact on both drives. The master password is also in this thread and in others as well!
PostPosted: October 15th, 2012, 6:10
Are you accepting the risks involved with DIY?
Your dump has the master password in plain text you just need to know what to do with it:
1) Download "MHDD v4.5" http://hddguru.com/download/software/mh ... 4.5iso.zip
2) Burn boot cd from the ISO image
3) Boot to the MHDD CD
4) You will see a list of harddisk, select a harddisk you want to unlock
5) Type "unlock" and reply "1" for master password
6) Enter the master password. “WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCW” without the quotes
(If it is wrong, ERR will turns red on the top of the screen, and You have 4 more tries before it powercycle the disk)
7) If it is correct, type "DISPWD" and reply "1"
(There will be a warning if your disk is still locked)
8) Retype the master password again and your disk is unlocked!
(ERR will turn red if the password wrong)
9) Type exit and press "ctrl + alt+ del" to reboot
Loki
PostPosted: October 15th, 2012, 11:52
I've tried similar instructions but not quite exactly yours.
After i got the 22.bin file, i used a hex app and i looked for the the passwords.
I then booted up with hiren boot cd-mini xp and launched the victoria app, selected the hard drive, and tried to unlock with what i thought were the passwords but to no avail.
thanks loki i will try your instructions and report back, also thanks dick for your reply as well.
-iplayball
PostPosted: October 15th, 2012, 12:12
-iplayball
Regarding MHDD make sure your drive is not connected using a usb caddy or usb cable ie use the SATA connection.
Also BIOS might need changing to compatible or IDE not Native or AHCI. If set to Native or AHCI then the drive will not be recognised by MHDD
Loki
PostPosted: October 15th, 2012, 15:03
thanks loki. i will try this when i get home tonight.
PostPosted: October 15th, 2012, 15:10
the piece of info that is almost ALWAYS missing is what happened to the drive up to this point what is the history on the drive ? Most never had a password on them or the WDC default and some firmware failure is causing the drive to now be "protected" or seem to be password protected
PostPosted: October 16th, 2012, 0:09
loki,
It worked man!!! Thanks so much!!
Just one question though, looking back at the 22.bin file, how'd you know that WDC... was the pw?
Is the pw always found within 130h-140h?
-iplayball
PostPosted: October 17th, 2012, 17:27
loki,
Please tell me for HDD WD1600BEVT it's same procedure and the same password ?
I tried but I can not unlook.
Thaks!
PostPosted: October 17th, 2012, 17:41
I'm not loki but I'll give you a reply...
pioneer wrote:
same password ?
Not always - often the software/firmware which sets the user password, also changes the master password (otherwise there is a hole in the (limited) security).
Please see the posting by networks 2 posts above yours and, as he suggests, explain the history to your situation, in order for readers to better understand what causes may apply in your case.
PostPosted: October 18th, 2012, 4:53
Hi pioneer,
The MHDD walk through post only works if & when you have found out the master password on that drive.
Unfortunetly in your case you say it didnt work which means the master password is different or you could have other issues?
Listen to Vulcan as he has a wealth on knowledge.
Another option is to take it to a DR company with the right tools who will be able to remove the password for a cost & proof of ownership. (if the data on the drive warrents it, if not buy a new drive?)
Otherwise you will need to do a lot more reseach
Loki
PostPosted: October 18th, 2012, 7:31
Thanks for those kind words, loki. :) I referred the OP to network's posting just as I don't want you or other members to waste your time being asked questions about passwords, if (for example) the OP never actually set a password, and this problem started after a power cut :shock:
PostPosted: October 18th, 2012, 8:54
Hi Ioki,
Sorry, I followed the instructions to finish (step 9). I typed in step 6 master password (WDCWDC....)the first time I came ERR and the second time I did not appeared red ERR. Passed over this step with your master password (WDCWDC. ..)
I followed the steps to finish but after reboot HDD was still blocked.
Hard drive is on SATA slot, have made certain settings in bios, I missing something?
Thank you,
Pioneer
PostPosted: October 18th, 2012, 10:22
pioneer wrote:
Hi Ioki,
Thank you,
Pioneer
Firstly your assuming the master password is WDC etc
You need to find out what the master password is first & then do the walk through.
Secondly other posters here did the hard work & went through using MHDD & script/batch file to get the a 22.bin file which had the master password in.
You need to do this if your going to try DIY (accepting the risks of DIY of cause?)
Loki
PostPosted: October 18th, 2012, 11:53
Hi loki,
Going to study earliest pages to find the master password with MHDD.
Thank you very much for your time,
Pioneer
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 67 guests
