 Post subject: Toshiba MK3265GSX HDD2H83 faulty
PostPosted: November 23rd, 2012, 5:46
I´ve got a faulty Toshiba MK3265GSX HDD2H83 320 GB 2,5" SATA notebook drive.
When I put the drive in an external SATA adaptor, the spindle is running.
Sometimes the PC even don´t boot up with this disc as a second drive attached.
I must attach the drive later. The drive is occassionaly not found within XP and if it was found after a long time of waiting I can see only empty partitions. I´m not able to run any diagnostic program. If I try this, the PC "looses" the drive and can´t see it anymore
Can anyone give me an advice for a good fault check strategy?
I already checked the PCB visually, but there is no physical damage to be seen. Is it a good idea to change the PCB and the ROM?
Thanks,
Luxman
 Post subject: Re: Toshiba MK3265GSX HDD2H83 faulty
PostPosted: November 23rd, 2012, 6:56
Total waste of time to change the PCB, it is not faulty,
Either you have media issues (bad sectors) and/or suspect head(s)
PostPosted: November 23rd, 2012, 8:07
Thanks.
Is there anything I can try at this point without opening up the disc?
I´m not a recovery pro.
PostPosted: November 23rd, 2012, 9:49
Unfortunately NO.
PostPosted: November 23rd, 2012, 10:59
Even with opening the disk you can't do anything. (and its not neccessary in my opinion)
Dobre
Murphy was an optimist
PostPosted: November 23rd, 2012, 11:04
To OP : I recommend dobrevjetser for pro service, if your data is important.
Users browsing this forum: Google [Bot], runner978 and 65 guests
