 Post subject: Tools to desolder/and replace the tiny Chips in the PCB
PostPosted: December 25th, 2012, 10:06
Is it physically possible to desolder those tiny Chips with even tinier legs from HDD PCBs ? I have read some comments about switching the firmware, and looking at those chips makes me wonder about the possibility.
Are there easier desolder tools ? Forget the soldering iron !
 Post subject: Re: Tools to desolder/and replace the tiny Chips in the PCB
PostPosted: December 25th, 2012, 13:11
Try searching hot air desoldering station, also you want one that you are able to control the temperature
Loki
PostPosted: December 25th, 2012, 14:41
Chip Quik SMD removal products if budget is a problem or you want to do just a few.
http://www.chipquik.com/store/prod_shts/prod_smd1.html
http://www.datasaversllc.com
PostPosted: December 25th, 2012, 15:49
Or outsource those procedures to a pro who does SMD work until you are proficient yourself.
Data Recovery Cape Town
PostPosted: December 26th, 2012, 4:08
With the right tools and a bit of practice..............you'll soon wonder what all the fuss was about... :D
http://www.eadr.co.uk
PostPosted: December 26th, 2012, 5:25
Thanks a lot for all the info. Could anyone, please, tell me where I can buy the Right tool.
PostPosted: December 26th, 2012, 10:36
http://gordak.en.made-in-china.com/prod ... 850B-.html
Low in both Price and quality , but does the job.
But a fine tip soldering iron(30/40w) of good quality is a must .
http://www.buildersmart.com.sg/store/in ... -iron.html
PostPosted: December 26th, 2012, 14:35
DON'T BUY CRAP TOOLS. You won't find spares , no support and you'll regret it at first disastered attempt, especially if you are a novice! I started with pro tools and I thank every bit of that decision, even if it took time to spare the money and/or mortgage. I had with them all the necessary support.
PostPosted: December 27th, 2012, 10:26
Thanks Blackst,
Can you please recommend a good quality too ?
PostPosted: December 27th, 2012, 12:24
Hello Matiw,
If you want a equipment to solder and desolder ROM chips you don“t need expensive tools. Otherwise you need to practice a lot because of the temperatures to avoid burning the chips.
YIHUA 892D+
You can look at it on ebay for exemple. Is an easy tool and will work for your needs.
PostPosted: December 27th, 2012, 22:33
Hello
To learn to solder / desolder you can read articles from www.zeph.com. products are sold well qualified
Users browsing this forum: mauriii and 225 guests
