Forum rules
 Post subject: Where is the AscII hiding?
PostPosted: December 26th, 2012, 18:00
I am vary old :-) and am trying to understand this technology. I am vary much a geek thou.
I have always been fascinated by the interface between two processors. So I built a serial cable and started looking around inside my seagate drive. (I used to do the same kind of thing on the vic20) The seagate 7200-12 only allows dumping of memory 1 block at a time. No big deal, I wrote a program that interfaces with realterm to keep downloading and saveing these blocks to a text file. I let it run all-night and accumulated quite a bit of data. Then this morning I used a hex editor to view the output. I was shocked to (not) see there were no ascii characters! Why not? What am I missing? I just figured it would display some of the hex as ascii data. I will gladly share the program I wrote for even a little information. :-)
Thank You!
Ron Derkis
 Post subject: Re: Where is the AscII hiding?
PostPosted: January 24th, 2013, 13:26
Thank You!
Ron Derkis
show us a screen shot?
