Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: how to unlock My Maxtor 250 GB locked accidentally
PostPosted: December 29th, 2012, 18:16
Hello from France.
I'm trying since 7 days to unlock my hard drive maxtor diamondplus 9 250 giga.
I Locked with linux with the command "lockhd -a" and when I put it in the xbox I get the error 06.
Im searching in the French forums and I find nothing, except to pay hdd unlock software for 20 euros to unlock the HDD , is not the goal, I come here I see that they are connoisseurs if somebody helps me be great thank you.
unlock -a not work
trying some MASTER pass not work , = Matrox inut test step with 24 space deosnt work
I see in your forum the tool HDD repaire, where i can donwload it please and how to use it
thanks
 Post subject: Re: how to unlock My Maxtor 250 GB locked accidentally
PostPosted: December 30th, 2012, 6:51
Hello from FRANCE
i search i your data base and i see a that somebody can read the matrox ata pass with HDD repair,security pass in module 191 b
I use it and I do not understand the pass:
pass#Ÿ%²ÖŸ)Ù2ÿ‡”‚´5µ™Ùï²
can you please help?
PostPosted: December 30th, 2012, 7:12
Selected port 170h
Poker Cpu Selected
Finish
Selected port 1f0h
Selected port 170h
Selected port 100h
Selected port 1f0h
Pasport in modul 8
seved
seved
seved
Map size 174
Read passport ...Ok
Passwort in modul 1b=191
Password:#Ÿ%²ÖŸ)Ù2ÿ‡”‚´5µ™Ùï²
Finish
PostPosted: December 30th, 2012, 7:33
hex edit i hange to char area and i get this pass:
ORgmbrR
i try to use it
PostPosted: December 30th, 2012, 8:13
ORgmbrR deosnt work
I use hirens cd boot,
any idea ?
PostPosted: December 30th, 2012, 10:01
arfff, I change ( build) the loader of my matrox 250 gb now the firm is other one and the HDD deosnt work
Maxtor 6Y250P6
I make a bad firmware please can one help me to change the matrox loader or firm with the good one?
thanks
PostPosted: December 30th, 2012, 10:52
i guess some how your profile IMAGE DOES NOT MATCH your post and Question here
no relation @ all
and i have a very good guess of where you are from, but doesn`t matter really
i cannot see any FREE password reset solution for you.
good luck
PostPosted: December 30th, 2012, 10:59
Iam lorie, from france. ? yes i know I dont speak very good english like you :)
PostPosted: December 30th, 2012, 12:30
All this mess to save 20 Eur.
I have a feeling the entire disk is screwed now (depending on what you did with FW).
P.s. This kind of discussions are usually dropped because of legal issues and we also do not give info that can potentially be used with nefarious intentions...
PostPosted: December 30th, 2012, 14:31
hi again
its because i locked it for my xbox 1 and now the HDD is not working because in HDD repair I think I write or change someting in the rom or RAM, I dont understand. now with HDD repair it show me that its Matrox YCR41VJ0 i know IO change the firmware :( seriam model was changed too !
can I change the right firm to this matrox?
PostPosted: December 30th, 2012, 15:09
You have NO idea about you were doing. Now there's almost nothing you can do with that tool - that is also INCOMPLETE. Ask someone in your area who has the right tools and know what they are doing to REFURB the drive loosing data but fixing it, maybe they can ask you 10-20 EUR. By the way, you SHOULD KNOW that most probably all data on your drive is gone. And next time think twice about using unknown stuff without knowledge. Good luck.
P.s. "maybe" data is still there, depending if you have overwritten or not the FW.
PostPosted: December 30th, 2012, 15:36
Just pay the €20 :-)
PostPosted: December 30th, 2012, 15:58
Now ? :mrgreen:
PostPosted: December 30th, 2012, 16:17
its not working cause I try with atapwd and i saw that the firm was changed the Serial number too and capacity 0 GB
any way because the good thing about making mistakes is that you learn from them.
PostPosted: December 30th, 2012, 16:19
No person in my area know how to use HDD and French forums are plenty of stuped guyes they just ask my phone number.
PostPosted: December 30th, 2012, 16:42
Well, then get another drive.
PostPosted: December 30th, 2012, 16:53
the thing with me even though I'm a girl when it does not work I always try to find and fix all alone.
like my car i fix it alone, we found alwaus solutions in forums ? no?
okay any idea how to fixe the matrox with HDD repair
Model DiamondMax Plus 9 250 GB
COde F:w YAR41BWO
SN: Y6581GEE
model :6Y250POSTD
I mean if anyone has the same and if he can give us loader.ld ,firm ,ram that I inject into or also if you have any other idea we can try all with this Matrox like a cobaye !
lol
PostPosted: December 30th, 2012, 17:21
Bonjour,
pour réparer votre disque dur essayez de formatage ou aller si vous avez un système d'exploitation Windows, puis aller pour commencer, puis mon ordinateur, puis faites un clic droit, puis gérer. essayez de cliquer delete volume, puis créer un nouveau volume simple.
PostPosted: December 30th, 2012, 17:25
No, your suggestion will not (cannot) work - the OP has already said that the drive is reporting a 0GB capacity (look earlier in the thread), which is typical of firmware-related problems. :(
PostPosted: December 30th, 2012, 17:26
MIKA wrote:
Bonjour,
what the hell are you saying !! we talk about a HDD losing FIRMWARE and you said to me to go to windows and to try to format it lol please my friend lets say the sages you're far from a connoisseur HDD
Users browsing this forum: Bing [Bot], Google [Bot] and 251 guests
