 Post subject: Problem with disk and HDD regenerator
PostPosted: January 30th, 2013, 6:40
I had problems to read data from a drive (a western digital caviar green WD20EARS) : reading data lead to cyclic redundancy errors, and eventually to a blue screen of death on windows.
I then decided to use HDD regenerator running on a laptop, with my hard drive connected with a SATA to USB adapter. I run it from windows, and after a while it quits working and says HD is not ready. I tried regenerating the drive by sectors, on a range instead of doing the whole drive, but it's all the same ; eventually I must power off/on the disk and regenerate the same sectors again...
I made a boot USB key and tried to boot the laptop from it but it doesn't work. Even with the 1st boot sequence on "removable"...
Is there a way I can fix my drive, with any software, or do you think the problem is physical and beyond any chance of repair?
Thank you for your help :wink:
PS : I already recovered most of the data I needed, so I'd just like to be able to use the disk again, for a while...
 Post subject: Re: Problem with disk and HDD regenerator
PostPosted: January 30th, 2013, 9:55
FYI: HDD regenerator is a big scam
PostPosted: January 30th, 2013, 10:17
Online
If your drive is under warranty, try and RMA it.
PostPosted: February 3rd, 2013, 6:51
Thanks for the tip but... which software isn't ?
Sorry the warranty expired on this drive.
PostPosted: February 3rd, 2013, 11:33
If full surface sequential write test doesn't help (unlikely would) then you cannot repair your drive
Caution: write test erases all the data
PostPosted: February 12th, 2013, 14:34
Thank you. If there's nothing to do about that, I think I'll just get rid of it... and buy a new one.
Thanks anyway!
Users browsing this forum: Majestic-12 [Bot] and 151 guests
