 Post subject: 5400.6 Partial Bad sectors repair
PostPosted: February 6th, 2013, 9:46
Hello
Does anybody know commands for terminal ?
for function "partial bad sectors repairs"?
THanks
 Post subject: Re: 5400.6 Partial Bad sectors repair
PostPosted: February 6th, 2013, 9:51
To do what, exactly?
PostPosted: February 6th, 2013, 9:54
Banned User
Do not do the translator regeneration on this drive, or you'll destroy the "Non Resident G-list".
I tried last year on a Momentus 5400.6, after the translator regeneration i had access only to few first LBAs, all other were inacessible.
If you already did the translator, you are in trouble!!
PostPosted: February 6th, 2013, 10:00
Banned User
BlackST sei italiano?
I don't know if you are really italian as it's wrote in your profile, if you're can you help me for a Pipeline HD.2?
faulty-heads-diagnosis-seagate-t25225.html
I can't write you a private message because i'm new :D
PostPosted: February 6th, 2013, 10:06
i need to repair unreadable sector after the half of the drive
i had some instruction how to do that
what do you think about that?
I want to run commands that are called "Partial Sector Accessibility" feature in SD Doctor.
7200.11; 7200.12 badsector general standard maintenance process
7200.11 and repair badsector standard method
F3 / T mode:
The first step: repair common fault
7200.11 use instruction m0, 2,2,0,0,0,0,22
7200.12 use instruction m0, 2, 2,,,,, and
Note: this step is to prevent the error after operation.
Step 2: clear SMART
/ 1 N1
Description: clear SMART + G, finished to power on.
Step 3: reset
/ T: m0, 5,1,3,5,,,,,,, and
The role of the equivalent MHDD erase erase logic bad way, stop to do 100% complete, intermediate quit that badsector too much, to carry out, such as is not complete, dish scrap, finish to power on.
Step 4: repair badsector
/ T: m0, D, 3,,,,,,,,, and
Specification, stop to do 100% complete, intermediate quit that badsector too much, intermediate quit that bad way too much, to carry out, such as is not complete, dish scrap, finish to power on.
Step 5: MHDD scanning badsector, a few can erase, no repeat step 3, 4, and not clear SMART, direct badsector to repair.
PostPosted: February 6th, 2013, 13:21
F3 / T mode:
Step 2: clear SMART
/ 1 N1
Step 3: reset
Within these commands are options to regen translator without using NRG, clear of G-list which will also clear NRG, command to render data inaccessible and other command to completely erase all sectors rendering data unrecoverable. Where did this info come from? Was it given to you with the promise it would help?
I hope you did not already try this....
Users browsing this forum: No registered users and 278 guests
