 Post subject: My dissaster HDD S.O. w7_64 Raid0
PostPosted: November 5th, 2012, 18:49
I did use physdiskwrite.exe (as administrator of W7 64 ultimate) for create a zeroshell S.O. ConpactFlash...
i create (think) and use my PC i7 normally two days witout poweroff using hibernation... when poweroff never start again...
The primary is a Raid0 mount on MB ASUS P6T WS pro
DVD W7 no see W7 intallation and no see disk, ini repair does not work
Bios and UBUNTU see the raid0, in Ubuntu see three partitions 1st ext3 2nd ? 3rd ? 4th space 1,9TB unmounted, first tree partitios are about 1,9gb and can be zeroshell
I need recovery as datas as possible of the 2TB Raid0
I am surprised whith physdiskwrite.exe (as administrator) as can be able erase and reformat SO HDD from the proper SO... can be possible? arghhhh
thanks in advance for attention
 Post subject: Re: My dissaster HDD S.O. w7_64 Raid0
PostPosted: February 27th, 2013, 4:01
i did reinstal fist 2 gb of raid0 erasing most important info of SO and HDD, howerver y see that can recovery many archives with R-Studio
in R-studio y use only NTFS exploration but dont know what type data on the menu exploration, 64kb archive 0kb separation?
PostPosted: February 27th, 2013, 5:18
Hi!
First rule! is you have to make a complete copy or image of that 2tb hard drive to another.
La primera norma! Hay que hacer una copia entera o imagen del disco duro de 2tb a otro.
Users browsing this forum: Majestic-12 [Bot] and 251 guests
