 Post subject: Htachi 1TB HDS721010CLA332 P/N 0F13656 just makes noise
PostPosted: April 15th, 2013, 11:36
Hello everyone and thank you in advance for any advice I can get.
I have attach pics and video + audio with oscilloscope readings of the drive.
The drive does not detect and it just make the same noise non stop.
Does it sound like a mechanical failure or could it be a bad pcb or firmware corruption?
hitachi_video_audio.zip [5.94 MiB]
Downloaded 541 times
 Post subject: Re: Htachi 1TB HDS721010CLA332 P/N 0F13656 just makes noise
PostPosted: April 15th, 2013, 12:24
Unfortunatly the noise is very bad, i would say bad heads + media demage.
Can you tell us the story of the drive? was it dropped down foer example?
Do you know that ONLY power-on a drive with so bad noises can increase the demages?
PostPosted: April 15th, 2013, 16:09
Hitachi arm with media damage. Unrecoverable. Sorry.
Murphy was an optimist
PostPosted: April 17th, 2013, 7:23
Sounds like a platter damage in 1 paltter.
PostPosted: April 17th, 2013, 14:12
I found out more info about the drive, it was in a external usb housing and it tilt over while it was on.
so I will also have to go with head/platter damage so very low chance to recover :(
Thank you all for your input/advice.
Users browsing this forum: No registered users and 51 guests
