 Post subject: Buffalo HD-CE1.0TU2 cannot be recognized by PC
PostPosted: May 6th, 2013, 17:26
My external hard disk just became inaccessible by PC. I've changed the PC and USB cables, but still no luck.
Symptoms: Hard disk keeps reading for 2 minutes then stops, but power is still on. When I click on the driver letter, Windows prompt not FORMATTED. Linux cannot mount the disk.
I tried out partition recovery software and successfully found the lost partition (files are intact). However, no matter how I save the partition table the disk just keep the UNRECOGNIZED...
Surprisingly, when I connect the disk to the TV, it can be read! I can play video / music flawlessly and can even delete files from it. No more symptoms like the above.
Could anyone tell me how I can fix my hard disk so that it will work again on the PC???
P.S.: HD-CE1.0TU2 has firmwares issues as I google it, however, I cannot flash the firmware due it will erase all my data.
http://news.softpedia.com/news/Buffalo-Acknowledges-DriveStation-Issues-Releases-Firmware-Upgrade-103827.shtml
 Post subject: Re: Buffalo HD-CE1.0TU2 cannot be recognized by PC
PostPosted: May 6th, 2013, 18:23
Could we see sector 0?
You could use a freeware disc editor such as DMDE:
http://dmde.com/
Users browsing this forum: Google [Bot] and 282 guests
