Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 30, 31, 32, 33, 34, 35, 36 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: May 1st, 2013, 3:44
amigo74 wrote:
can anybody send me an pn with the right password, i can´t find it in the 22,image ????????
You have already been advised to read page 3 and there you will find the answers
I don't know but your password was set by the bios so the password in the 22 dump might be different from what has to be entered directly during the emachine start up. So you might find it easier to enter the password using Victoria or Mhdd or the like.
PostPosted: May 1st, 2013, 5:00
Spildit wrote:
Click READ.
Tick Head0 and Head1. Click write.
You might also have to fill in the other information, like number of heads, heads in use, etc ....
If all the rest fails, copy that information from a known good equal drive.
It fails, can't read or write.
My problem continued here http://forum.hddguru.com/viewtopic.php?f=1&t=25895
Those who know don’t talk. Those who talk don’t know.
PostPosted: May 6th, 2013, 14:34
that can't be unlocked by conventional methods (like ... ZU
ZU can.
you need to choose right port & M/B chipset.
PostPosted: May 6th, 2013, 15:05
If drive rejects Techno Key or keep access to SA "locked" then ZU can't read module with password at all.
ZU can. :wink:
No software can unless you start the drive in safe mode or swap pcb ...
pcb-swap is not necessary
ZU was tried on that locked drive ... and failed.
zu works only on channels (/p & /s) and only in IDE-compatibility mode. (M/B i865,i440BX+IDE-->SATA converter,i440LX+IDE-->SATA converter & other)
an acer notebook
it may not meet the above requirements
Did you test ZU with WD1600BEVS-08VAT2 ?
that does not important
http://www.ihdd.ru/forum/pomogite-sovet ... 4-220.html
Zephyr
c:\_save.2011\110924\#zu.unlocker.050911>zu /s
ELAPSED 00:00:01
03.01A03WDC WD5000BPVT-75HXZT3
UNLOCK DONE
Jamaica
ELAPSED 00:00:01
01.01A01WDC WD2500BEVT-35A23T0
UNLOCK DONE
Mariner
ELAPSED 00:00:01
01.01A02WDC WD5000BEVT-24A0RT0
UNLOCK DONE
Hubble
ELAPSED 00:00:01
01.01A01WDC WD2200LPVT-22G33T0 .
UNLOCK DONE
PostPosted: May 6th, 2013, 15:23
Are you changing something on RAM on the fly to gain access to SA again ?
no.memory(RAM) access (read & write) is also prohibited. (cmd= ok!,but no DRQ)
(MHDD SCRIPT)
MHDD can.
need to know what to send to the disk.
method & program is not important.
PostPosted: May 6th, 2013, 15:40
PapashaBeppe
In this topic volosator has a Lenovo notebook hdd
WD3200BEVS-08VAT2 SATA FW:14.01A14 and could not unlock the drive with zu.
I have WD1600BEVS-08VAT2_14.01A14 and zu.betta.050911 couldn't unlock the drive.
I tried another non-Lenovo WD hdd and MHDD could read password module, while MHDD couldn't read the Lenovo hdd. I guess zu could have unlocked it, but it wasn't locked.
PostPosted: May 6th, 2013, 15:49
his drive was not working properly (write error)
because you tried to take it off in Acer.
08VAT2 this Denali.
with Denali no problems have been reported.
while MHDD couldn't read the Lenovo hddI guess zu could have unlocked it, but it wasn't locked.
zu works by other method (than MHDD Script).
PostPosted: May 6th, 2013, 16:06
I didn't see mentioning any write errors, his drive died, that's what he said.
I tried with MSI P965 Neo mobo, also.
PostPosted: May 6th, 2013, 16:09
Spildit wrote:
Mind to give us a "clue" about how zu does it ?
Thanks.
all very simple.But the information (about the commands) is still closed.
Try using grabber. :oops:
PostPosted: May 6th, 2013, 16:17
I tried with MSI P965 Neo mobo.
Ноw do you use the port ? What was the version of zu ?
you're an expert on the disks ? :wink:
PostPosted: May 6th, 2013, 16:22
Spildit wrote:
Would "Safe mode" and "load from a loader file" bypass the ATA password on a WD drive like this and allow read/write access to SA ? I don't have this model of drive here with me to test.
this extra work.
although the method of shiftings the regions must help.
PostPosted: May 6th, 2013, 16:27
this extra work.
although the method of shiftings the regions (correction HM,"clear" mod 30h in ROM,...)must help.
PostPosted: May 6th, 2013, 16:28
me expert? :lol:
I connected to sata port, tried all ports, none worked. Set bios to compatible mode. As said I used latest zu. (3664 bytes, 050911)
Don't have sata-ide adapter. so couldn't try ide port.
PostPosted: May 6th, 2013, 16:36
helpless wrote:
me expert? :lol:
to which port ?
SATA have been secondary ?
http://www.hddunlock.com/support/faq/#12
HDD Unlock Wizard does not recognize my hard drive
Please make sure that your motherboard IDE/SATA controller is not running in AHCI/RAID mode.
Also, some chipsets (for example, SiS) and most PCI IDE/SATA/RAID controllers (for example, Promise, SiI/Silicon Image, HPT, Adaptec) do not support special non-standard protocol that HDD Unlock Wizard uses. We suggest that you only use standard IDE/SATA ports on your motherboard. The motherboard itself should not be based on a SiS chipset.
If these suggestions do not help, then please try HDD Unlock Wizard on a different platform.
me expert? :lol:
what i'm saying. :lol:
so you do not know what happened to his drive.
PostPosted: May 6th, 2013, 16:49
Spildit wrote:
edit it and use module 105 on SA to write back 30h on ROM ?
? need to write mod 30h from backup.
Module is not easy to clear. :wink: Need to edit the ROM dump
try removing it entry from the 0B(020B)h
But,all this extra work.Too dificult. :)
What about if i clear ROM mod 47h (adaptives)
here do not have.
PostPosted: May 10th, 2013, 5:24
PapashaBeppe wrote:
helpless wrote:
me expert? :lol:
to which port ?
me expert? :lol:
Are you an expert?
Tell me please what am I doing wrong? Lenovo WD 2.5" hdd with password.
PostPosted: May 10th, 2013, 9:03
do not know :oops:
was
WD1600BEVS-08VAT2 14.01A14
now
WD800BEVS-08VAT1 13.01A13
This is second drive or the drive after turning off the head ?
I need firmware mods from their.
PostPosted: May 10th, 2013, 9:37
PapashaBeppe wrote:
ZU can.
WD1600BEVS-08VAT2 14.01A14 or WD800BEVS-08VAT1 13.01A13, makes no difference, they are same drives just different capacity, neither can be unlocked by zu :( .
WD1600BEVS could be unlocked by pcb swap because I had 2 identical drives and could read security sector.
Can't do the same with WD800BEVS, because I haven't got another identical drive. Tried with WD1600BEVS PCB, PCB number is the same, but all modules remain hidden. :(
Also have a Hitachi (Lenovo) HDD, HTS541660J9SA00 with same problem.
I asked author of zu about the new version, but didn't reply.
Or are you the author in disguise? :D
PostPosted: May 10th, 2013, 9:46
I do not know where you asked. 050911 should support HTS541660J9SA00
ok.i find myself this F/W
PostPosted: May 10th, 2013, 11:58
This is second drive. I didn't turn off heads.
Which mods do you need?
I sent a PM to this user. Maybe not the right person?
Users browsing this forum: No registered users and 66 guests
