 Post subject: SAMSUNG HM641JX - USB interface (log from terminal)
PostPosted: June 4th, 2013, 17:19
Hi again Guys
Can anyone interpret the log from terminal.
Drive is trying to spin in numerous times.
Thank you
This is the log:
*PA VID=0007 PN=0000 Rev=0004*PA VID=0007 PN=0000 Rev=0004ChipRev = 63B0U
S_0Shock Sensor Circuit Enabled
SO_1
IS=4
CLA #36/98
Handoff RPM=461
SPOK
mS1 00000003
A1O=1 A1G=435
O=514 S=8
***** No Gray
SoUL!
Abnormal end
PK_3 C: 0 H:0
SO_1
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
SO_2 C=5,A=0,S=1,RPM=0
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
SO_2 C=5,A=0,S=2,RPM=0
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
SO_2 C=5,A=0,S=3,RPM=0
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
Shock Seî*PA VID=0007 PN=0000 Rev=0004*PA VID=0007 PN=0000 Rev=0004ChipRev = 63B0U
SO_1
IS=6
CLA #36/109
Handoff RPM=3468
Rampup TMO : 00000026
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 1 RPM = 3898
IS=4
CLA #36/141
Handoff RPM=3809
SPOK
mS1 00000003
A1O=1 A1G=439
O=514 S=4
***** No Gray
SoUL!
Abnormal end
PK_3 C: 0 H:0
SO_1
IS Fail
CSRTY=1 RPM=766
IS Fail
CSRTY=2 RPM=766
IS Fail
CSRTY=3 RPM=766
IS Fail
CSRTY=4 RPM=766
IS Fail
CSRTY=5 RPM=766
SP Startup Fail
SO_2 C=5,A=0,S=1,RPM=766
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
SO_1
IS=2
CLA #36/114
Handoff RPM=3439
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 1 RPM = 3852
IS=1
CLA #36/127
Handoff RPM=3812
SPOK
mS1 00000003
A1O=1 A1G=441
O=514 S=3
***** No Gray
SoUL!
Abnormal end
PK_3 C: 0 H:0
SO_1
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
IS Fail
CSRTY=5 RPM=0
SP Startup Fail
IS Fail
CSRTY=1 RPM=0
IS Fail
CSRTY=2 RPM=0
IS Fail
CSRTY=3 RPM=0
IS Fail
CSRTY=4 RPM=0
...... to the infinity
 Post subject: Re: SAMSUNG HM641JX - USB interface (log from terminal)
PostPosted: June 5th, 2013, 1:08
Does the drive spinn? If not I would say stucked heads.
http://www.rescue-it.se
PostPosted: June 5th, 2013, 12:30
Yes, drive spinn -> head move over or on the edge of platters -> drive slow down -> a few clicks -> story begins again drive spinn .....
May be some head is hiting the surface of platter.
Can any one explain this line by line?
CLA #36/98
Handoff RPM=461
SPOK
mS1 00000003
A1O=1 A1G=435
O=514 S=8
***** No Gray
SoUL!
Abnormal end
PostPosted: June 6th, 2013, 11:58
It doesn't matter - apparently, 99% it has been shocked and the outcome is either media damage, head damage or mixed damage. Inspection can tell.
PostPosted: June 6th, 2013, 16:35
Heads damage or SA bad sectors.
Recuperacion De Datos Dominican Republic
PostPosted: June 7th, 2013, 14:35
Banned User
You definitely have read write heads damage. I recommend you not powering up your drive no more, if data is important for you. If heads are touching the surface, you will probably hear some scratching sound and in 95% time you lost your data.
Users browsing this forum: Google [Bot] and 37 guests
