 Post subject: Please: PCB Urgently Needed
PostPosted: June 9th, 2013, 11:38
I would please love a bit of help. I smoked out my PCB after I plugged in a DC rather an AC. There was no smell from the Drive as it comes on and shows as drive connected on OS but I cannot access it. After a few consultations with almost 5 specialists, I was told to get.a replacement board but unfortunately I cannot seem to find either the HDD as they no longer manufacture it nor the PCB, which then led me to this forum. The HDD in question is detailed below,
HDD: Freecom HDD (500GB)
S/N: 7140801362
P/N: 28604
PCB Details
Model No: 2060-701590-000 (Rev A)
(Sticker Details)
Part No: 2061-701590-J00 AD
XC-7K104292 J 0003480. (9483)
If anyone is able to assist me with this board I will be very appreciative of the time taken.
Thank you.
 Post subject: Re: Please: PCB Urgently Needed
PostPosted: June 9th, 2013, 11:48
hello
Some WD10EACS drive pcb have the same PCB, but you ll need pro tool to moove rom content to new pcb, cause no U12 (if my memory is good)
Good luck
Récupération de Données
PostPosted: June 9th, 2013, 19:44
w.simon wrote:
hello
Good luck
Still tryna get the hang of replying pm's. Thank you for you response but unfortunately I could not find the PCB anywhere
Manufacturer is Western Digital (Not Freecom)
Date is 31st May 2009 (From Thailand)
Model is WD10EADS (2060-701590 000REVA)
Sticker No: 2061-701590 J00AD (XC 7K104292 J0003480. 9483)
Would really appreciate any help :(
PostPosted: June 10th, 2013, 1:35
HI
There was no smell from the Drive as it comes on and shows as drive connected on OS but I cannot access it. ?
i doubt your Drive have PCB Issue need more information..................... if the Drive is Detecting in Os it means PCB is fine (can u check Drive is showing Right Capacity,Model & Serial Number)...
PostPosted: June 10th, 2013, 3:17
+1
Need more info as exactly how the drive behaves.
Regardless of that, 701590-000 is a very common pcb, I could find 100's in just one minute.
PostPosted: June 10th, 2013, 3:58
so does the hard drive say the correct information name model etc
its also possible it might had damaged the headstack
PostPosted: June 13th, 2013, 15:30
with regards to the samsung HDD, Actually i took The HDD out of its enclosure and mounted it on an external docking station but unfortunately it comes up with nothing on the screen and its not even spinning. No info came up on the screen whatsoever???
Any other suggestions please?
PostPosted: June 13th, 2013, 15:34
+1
with regards to this PCB, i discovered that even if you get the right PCB you still need the right firmwire to make that particular HDD work. Therefore i investigated further that those HDD (Western Digitals) have a diode just by the power pin that burns out immediately after a wrong power cable is plugged in in order to protect the board so once taken out you can with a docking station still get to your drives. Gonna try it out though as i am not 100% sure about this.
PostPosted: June 13th, 2013, 16:26
Things are not quite that simple - sometimes other components are affected too. Also, if the diode was your problem, you would not expect to have the behaviour where it "shows as drive connected on OS" (as microsoftengineer explained). Unfortunately your descriptions has not been clear & detailed enough to fully understand (as northwind said). Also, you just started to mention Samsung, yet previously you said the drive was WD. You are confusing readers by changing your story like that. :(
So based on your description that it "shows as drive connected on OS", I doubt that your drive has the simple TVS diode problem which you mention. However with a confusing and unclear story, anything is possible. If you want to read more about the diodes which you mentioned, search on the forum for TVS. If you decide to do some DIY as you say, then I wish you good luck, but remember that depending on what you actually do, you could make things worse (perhaps much worse), and could make any possible later recovery more expensive / less successful / perhaps impossible. Your data, your risk, your responsibility, your choice.
PostPosted: June 13th, 2013, 16:50
Thanks for the swift reply and sorry for the confusing state of things. Let me be much clearer that there are 2 HDD's in question. The first one happens to be a samsung 500GB model (HD501LJ) date (03/2007), PCB (BF41-00133A Trident 11-RE Rev06). This hard drive shows on the OS without any access. It powers with the casing but totally quiet and not happen to be spinning either.
The second hard drive is a western digital (WD10EADS) date (31/may/2009) PCB (2060-701590-000 REVA). Now this hard drive had a funny smell when wrong power source was plugged in. Opening it up and removing the PCB, the diode close to the connector on the right hand corner (picture attached) looks burnt. This is where my reasearch came in that it was the diode that needed replacement.
Picture attached. So sorry for the confusion :)
File comment: The burnt diode shown on the top right hand side
PostPosted: June 14th, 2013, 2:27
The problem could be as simple as a shorted TVS diode, in which case just remove it and make sure you don't overvolt your drive again.
See http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html.
The same goes for the Samsung. There are several TVS diode photo clips here:
With any luck, the whole exerecise should cost you nothing.
Good luck.
PostPosted: June 18th, 2013, 5:02
We have this PCB.
This PCB's BIOS is integrated on the Main Controller IC. You should exchange the Main Controller IC to let the HDD be recognized. Move the Main Controller IC(the biggest chip on the board) is a complex job which need you have certain techique. Some electronics repair shop can do it.
PostPosted: June 18th, 2013, 15:29
I have this pcb available do u want to buy plz Pm me .....
PostPosted: June 18th, 2013, 15:59
Thank you guys for your input fortunately, I was able to retrieve the files after removing the "TVR" diode which shunted the circuit board and I have there fore replaced it not the drives are as good as new. And to @fzabkar the link you provided was of a huge help understanding those diodes.
I guess I just saved myself 400 quid of data extraction
Users browsing this forum: No registered users and 106 guests
