 Post subject: error loading hdd
PostPosted: June 19th, 2013, 16:08
Hello
I connect a WD5000bevt drive an the HD shows busy and after that shows Err
How to repair please
Thx
 Post subject: Re: error loading hdd
PostPosted: June 19th, 2013, 16:16
the status is ready and when i want to load hdd Hd doctor shows the error
help please
PostPosted: June 19th, 2013, 22:47
Seems like firmware is not read for some reason.
Can you describe the drive's physical behavior after power on?
PostPosted: June 20th, 2013, 4:30
Probably you will find that spindle is stopped, and is a physical issue.
PostPosted: June 20th, 2013, 4:43
the drive spin well and there is no strange sound
thx
PostPosted: June 20th, 2013, 6:52
Let's eliminate the obvious: PCB is native?
PostPosted: June 20th, 2013, 15:57
yes pcb is native thx for helping
PostPosted: June 23rd, 2013, 16:04
did you try to load in LOW SPEED when it's REAYD?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: June 27th, 2013, 18:02
no mods readed
i also try to load by low speed
thx
PostPosted: October 1st, 2013, 12:52
Spildit wrote:
If you need the data from the drive you can try Hot Swap and see if you can gain access to SA that way .... If not Heads/Pre-Amp might be damaged.
If you can gain access to SA by hot swap you can then copy the defect lists and translator to the donnor drive and do a smart hot swap to get data back.
Actually i had a WD MY BOOK that freezes reading the plist and i cannot acces the data also because of the damage and the drive cannot be detected without the usb controller board from WD. Can i do something about it doing that?
