 Post subject: DiamondMax 21 STM3320820A fw 3.AAE knocking sound
PostPosted: July 18th, 2013, 10:10
i've this DiamondMax 21 STM3320820A family GALAXY 2D with firmware 3.AAE which spins up but doesn't calibrate, it does knocking sounds (about 1 every 2 seconds).
Motor doesn't spin down.
PCB number: 100414872
Sticker label: 100486542
MCU: 100427288
Teminal log:
F> HM HM HM HM HM
'for ever'...
At the moment i don't have an identical pcb donor to do other test, but i have a similar one.
So i tried to swap with donor:
PCB: 100406538
Sticker label: 100406536
MCU: 100427287
Drive spins, doesn't do any knocking sound, but is not detect in bios (haven't done yet the rom transfer).
Is this a PCB issue or something else?
Is this donor pcb compatible with mine?
How can i check the original pcb?
(i have a multimiter)
If you say that is compatible i can try to swap ROM.
My firmware database:
 Post subject: Re: DiamondMax 21 STM3320820A fw 3.AAE knocking sound
PostPosted: July 18th, 2013, 10:19
michael chiklis wrote:
Teminal log:
F> HM HM HM HM HM
'for ever'...
Heads are bad
PostPosted: July 18th, 2013, 10:49
I don't understand, if heads are bad why doesn't spin down?
PostPosted: July 18th, 2013, 11:08
Different architecture. Modern Seagate drives have technology based on SCSI architecture, pre-F3 dont,
PostPosted: July 18th, 2013, 11:19
ok thank you.
PostPosted: July 18th, 2013, 12:09
Well, if you intentionally damage part of the code or mix it , even pre-F3 will forcefully spindown ... :mrgreen:
Users browsing this forum: No registered users and 187 guests
