 Post subject: WD Scorpio Blue 2.5
PostPosted: July 24th, 2013, 2:51
I have a WD 2.5" Scorpio Blue (Model WD5000BEVT-00A0RT0).
When I connect it to PC3000, it is recognized, it reaches readiness but with errors. When the drive spin, I can hear an strange sound.
When I run the utility, the model in not read and when I choose the model Scoprio, and I get the logs bellow:
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 16.0SW
ROM generation.......................... : 16.0SW
Link table version...................... : 07.17.
Consolidated ROM version................ : 0016000S
ROM Modules:
Head Map Reading Error.................. : Head map check sum error
ROM Firmware version.................... :
Service area:
SA dir reading (ID)..................... : DISK SERVO SPINDLE SPINUP ERROR
Configuration reading................... : Module 02 not found
Any procedure or solution to resolve the problem please?
Kind regards,
 Post subject: Re: WD Scorpio Blue 2.5
PostPosted: July 24th, 2013, 17:31
Sounds like you are using pc3000 pci version, not UDMA.
PostPosted: July 25th, 2013, 4:47
Hello All,
Many thanks for your help.
Yes I'm using PC3000 PCI.
I hear 5 times a quit sound then the sound stop (I'll check again if the drive continue to spin)
Kind regards,
PostPosted: July 25th, 2013, 9:08
The drive stop spinning after I hear 5 times a quit sound.
It should be a bad heads.
PostPosted: July 25th, 2013, 18:08
If it was stiction or spindle, the drive never reaches readiness. Correct me if I'm wrong.
PostPosted: July 26th, 2013, 2:58
Yes, bad heads.
PostPosted: July 26th, 2013, 3:19
I started the drive in normal mode and in safe mode.
PostPosted: July 26th, 2013, 4:03
Most likely read/write heads are damaged.
Think before you act => Most of the time there is only one chance for recovering lost data !
PostPosted: July 26th, 2013, 4:44
RAM:
ROM:
ROM Modules:
Service area:
Kind regards,
Hi Dear Friend Sosrecup
Dear Friend Read The Diag Carefully.
That Mean Problem In If Drive Dont Get Head Map Then Its Not Reach Readyness. Not Able To Read Information. And No When No Information Awailable U Know What Happend.
Its Caused By Bad ReadWrite Head. But When U Change The Head First Try HOTSWAP Method I Have Many Time Its Happend That I Recover Data From Hot Swap Tipical This Type Of Cases.
Your Friend
Jignesh Pankhania
Users browsing this forum: No registered users and 14 guests
