Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: SCSI Adapters
PostPosted: September 14th, 2013, 14:58
The answer to your first question is yes
PostPosted: September 14th, 2013, 15:53
Both drives appear to be OEM versions of Seagate's ST3146707LC.
http://img.auctiva.com/imgdata/1/3/8/8/ ... 186_tp.jpg
BD14688278 = ST3146707LC
http://autos2.bluesock.com/ebay/farnbor ... /13576.jpg
BD146BA4C5 = BD1468A4C5 = ST3146707LC
Compare the jumpers at J2, particularly the SE (single ended) and TP (terminator power) jumpers.
See page 48 of the manual:
Cheetah 10K.7 SCSI Users Guide:
http://www.seagate.com/staticfiles/supp ... 60915d.pdf
PostPosted: September 14th, 2013, 16:09
It appears that section 1.1 of the HBA manual allows mixing both LVD and SE devices on the same cable.
Ultra320 SCSI Host Adapters User's Guide:
http://www.lsi.com/downloads/public/scs ... 320_ug.pdf
However, page 67 of Seagate's manual states that "all devices must operate in the same mode, either SE or LVD, but not a mixture of these".
PostPosted: September 14th, 2013, 19:06
Thanks, what really confuses me is that on the sticker of the drive itself it says LVD/SE..
PostPosted: September 14th, 2013, 20:04
That just means that it is capable of either configuration, but you need to choose one or the other via a jumper.
PostPosted: September 14th, 2013, 23:00
Hmm, My drives don't have the J2 Jumper option
PostPosted: September 15th, 2013, 1:20
Sorry, there is a footnote on page 49 that states that J2 does not exist on LC models and is supported on LW models only. Figure 20 says the same thing, but there is a confusing note that states that the TP jumper (Terminator Power) "applies to LW models only; reserved on LC models".
I wonder if, even though the header may be absent, the various options may be strapped into the PCB via preset etches.
Anyway, it looks like I may have introduced a red herring. :-(
PostPosted: September 15th, 2013, 1:34
Here is the label for an -LC:
http://tig-rynek.home.pl/apress/SKLEP/D ... 07lc/3.jpg
It has a jumper layout diagram.
This photo of an -LW has no jumpers:
http://www.ixbt.com/storage/scsi2005/ro ... w-back.jpg
Now I'm really confused.
PostPosted: September 15th, 2013, 1:52
It has a jumper layout diagram ...
... but it states "for LW only", so why bother mentioning it???
PostPosted: September 15th, 2013, 3:18
I think I understand the difference between the 80-pin and 68-pin drives.
Seagate's 80-pin -LC drives obtain certain signals from the SCSI interface whereas the 68-pin models obtain these signals via jumpers.
One of these signals is DIFFSNS (pin#46 on 80-way cable). Others are RMT-START and DLYD-START (remote and delayed start).
ISTM that your drive needs to get a DIFFSNS signal from the HBA in order to configure itself for LVD mode. Since this signal is not present on the 68-pin cable, then the drive defaults to SE mode. I don't know whether this is the cause of your problems, but it might be worth looking at. If possible, you could try to fudge an appropriate +1.3V signal on this pin to force the drive into LVD mode. If you could show me the underside of your PCB, perhaps we could see how the jumper section is trapped. You would need a Torx screwdriver to remove the board.
The following datasheet might shine some light on the subject:
http://www.ti.com/lit/ds/symlink/ucc5680.pdf
BTW, which of your two drives is the working 68-pin drive?
PostPosted: September 15th, 2013, 16:55
Have you tried installing the SYN jumper? I suspect this may be the DIFFSENS signal that determines the SE/LVD mode of the drive .
PostPosted: September 18th, 2013, 17:17
Thanks for the tip, I'll post if it works or not
PostPosted: November 4th, 2013, 20:41
I never could figure it out, if anyone would be interested in these drives i'm selling them for 20 each, there's three...
Users browsing this forum: Majestic-12 [Bot] and 62 guests
