Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Force Seagate 2.5" SSHD ST1000LM014 to SATA1
PostPosted: September 23rd, 2013, 15:22
I posted this in a topic covering a similar situation (forcing a drive to 1.5 Gbit/s) albeit with a Western Digital drive. Perhaps this creates some confusion hence I decided it could be better to create a new topic for this drive family only. Apologies for this; learning the customs on this forum! Also wanted to say hello and thank you all for sharing some of the knowledge HDD manufacturers would rather keep in their labs... makes me really thankful that we have the web and some awesome people using it.
I recently purchased one of those Seagate 2.5" Solid State Hybrid Drives, the ST1000LM014. It is able to run at SATA 3 (6 Gbit/s) speeds, but my notebook does not like that at all. According to my research, even though the chipset (nVidia's MCP79) advertises its ability to communicate at 3 Gbit/s, it has troubles actually working at this speed with some drives. Choking them to 1.5 Gbit/s apparently solves all the problems (eg. OS freeze).
So long story short, I'd like to force my ST1000LM014 (firmware SM15) to 1.5 Gbit/s. Some of the previous Seagate models, eg. the Momentus XT family, honoured jumper settings for this (two leftmost pins with HDD facing PCB-side-up) but this drive sadly does not :( It seems that I need to either invite it to honour the jumper (a "SATA gen I 1.5Gb/s Jumper Supported" software setting mentioned in the other thread on the WD drive?) or somehow force it to only advertise support for 1.5 Gbit/s to the controller.
I'd be fine doing this via the serial interface or any other tool, but wanted to know if it can be done at all without low-level programming? I've read all the Seagate console commands but there is none specifically for this, at least according to the command lists I've acome across...
 Post subject: Re: Force Seagate 2.5" SSHD ST1000LM014 to SATA1
PostPosted: September 23rd, 2013, 22:51
after deploying recently 130 laptops in an edu environment, I can say there are many issues relating to newer hardware.
I don't think you are going to find a solution for that drive. a similar thread, and answer:
Re: I/O error with ST1000LM014 in Macbook Pro (late 2008)Optiion
Well, here's my conclusion for anyone who might suffer from the same problem:
It seems that Nvidia SATA controllers (in my case MCP79 used in late 2008 models) have certain incompatibility issues with 6 Gbit/s harddisks which causes random i/o errors.
One rather difficult option (I have not tried) that might 'fix' the problem is to revert the EFI update that enabled 3 Gbit/s mode. But that leaves you with 1,5 Gbit/s which is a bit slow for modern drives.
sometimes admitting defeat lets you sleep easier at night again a lot earlier ;)
PostPosted: September 24th, 2013, 3:53
HaQue, thanks for input, good to see someone reply :) You are right in that the quote you... quoted describes the problem exactly, thou unfortunately in my case a firmware rollback has not been put forth by Apple (an doing this the unauthorized way is apparently not as easy as it sounds, as Apple prohibits you from rolling firmware back) and secondly, according to Apple changelogs, earlier firmwares for my particular model would not disable 3 Gbit/s mode anyway :( This was only the case with 2009 MacBook Pro models, mine is late 2008.
So all Apple-side LEGOs being taken away from me, all I have left to play with is the drive itself.
Would prefer not to admit defeat without a fight ;) A TTL-USB interface is on its way, will give it a try when it arrives if only "for science" and posterity's sake.
PostPosted: September 24th, 2013, 6:20
Ok, well once you get the interface it will be interesting to see how you go.
Cheers
PostPosted: October 22nd, 2013, 16:43
A small update. I connected the drive to a USB-TTY converter but are not able to communicate with the drive. My setup is as follows, with 'up' being PCB-side: [EMPTY GNDcable RXcable TXcable] [.......] [..................].
I've tried different COM port speeds and even parity settings but still all I get is random characters in the PuTTY console window when I type in ctrl-z or letters to see if at least it echoes what I write. Any clues on what would the correct way to communicate with it be? Is it possible that this is a newer drive that eg. encrypts serial communication or uses some strange baud rate just to make it harder for anyone to connect?
PostPosted: October 23rd, 2013, 5:45
Seagate uses: 9600 or 38400 OR NONE
None means NO TERMINAL ACCESS = Drive Blocks Terminal Output = Need to Short Certain points in Specific Timing to bypass it (Depends on PCB)
good luck
:wink:
PostPosted: October 23rd, 2013, 6:00
Hm, how would you interpret this then? :) Console output of ctrl+z pressed twice, then just the letter "z". Not all key presses had visible output.
At baud 9600:
At baud 38400:
PostPosted: October 24th, 2013, 3:30
I guess your problem with terminal output is from Putty (Limited options)
have a look here @ the images
PostPosted: October 24th, 2013, 3:59
einstein9, thank you for your efforts and helping me getting a stab at this drive's speed. Unfortunately, it seems that HyperTerminal gives me the same output (again ctrl-z ctrl-z and then just letter the "z" all the way):
PostPosted: October 24th, 2013, 5:29
Putty limited options compared to hyperterminal ??? :-)
look at the options under the "terminal" menu. If you have played around with options such as local echo, the CR and LF options, or stuff under the "keyboard" sub menu, try getting them back to default.
or as einstein9 suggests, try using HyperTerminal as the less "features" may mess with the terminal less and not give that corruption.. OR your firmware could be dodgy and not working properly I guess
PostPosted: October 24th, 2013, 6:05
also, you might try this program from:
https://code.google.com/p/baudrate/
Baudrate is a tool to help quickly identify the baud rate of an unknown serial device. It displays received data from a serial device while allowing the user to change the baud rate of their host system's serial port on the fly.
PostPosted: October 24th, 2013, 11:12
ISTM that the USB-serial bridge is OK, but you could confirm this by connecting its Tx and Rx pins and performing a simple loopback test by typing on the keyboard and looking for echos.
Next I would measure the voltages at the jumper pins on the drive to determine whether the interface is 3.3V or 2.5V.
Then do the same with your bridge's Tx and Rx pins, with it disconnected from the drive.
That said, it does look like a baud rate or framing issue.
PostPosted: October 25th, 2013, 3:12
Did this before connecting my drive to make sure the bridge all of my soldering is fine; passed without any problems.
Next I would measure the voltages at the jumper pins on the drive to determine whether the interface is 3.3V or 2.5V. Then do the same with your bridge's Tx and Rx pins, with it disconnected from the drive.
Seems you may have nailed it here! I measured 5.0V and 4.8V on the bridge pins (Tx and Rx, respectively), but voltages were as low as 1.76V on the HDD...
From what you're saying I need to lower my voltage to around 2.0V on both the Tx and Rx? (Assuming that I have not yet burned the drive's serial interface and just lowering voltages will make it happy enough to talk to me.) From your collective experience, what sort of a current the interface may draw? Need this to estimate what resistor i should plug in between my interface and the drive.
PostPosted: October 25th, 2013, 11:10
Try also the 57600 (same config) - This is for Samsung, which i guess your drive is
good luck again
PostPosted: October 25th, 2013, 11:28
Does the drive carry an APPLE logo ?
PostPosted: October 26th, 2013, 17:21
"ST1000LM014 (firmware SM15)" is a Seagate drive, AFAIK. The part number (1EJ164) also looks like Seagate.
PostPosted: October 26th, 2013, 17:36
The four jumper pins would be wired to the MCU's I/O logic. This would be powered from the drive's Vio supply. It appears that Vio may be +1.8V.
I don't know the specs for your MCU, but many of these devices can tolerate 5V signal levels. Nevertheless, I would play it safe and use a 1.8V or 2.0V zener diode to clamp the input to the drive.
The USB-serial bridge IC can usually be programmed for 5V or 3.3V I/O, so I would try to jumper it for 3.3V, or 2.5V if available. A 5V TTL interface will usually have an indeterminate range between 0.8V and 2.0V, so it could be that a 1.8V input is not being reliably detected.
PostPosted: October 27th, 2013, 16:31
You may be able to determine the input range of your USB-serial bridge by means of a potential divider in the loopback path.
        Tx o---------| 0V - 5V
                     R1
        Rx o---------|
                     R2
       Gnd o---------| 0V
R1 = 3K3, R2 = 1K2 --> Rx = 1.33V
R1 = 3K3, R2 = 1K5 --> Rx = 1.56V
R1 = 3K3, R2 = 1K8 --> Rx = 1.76V
R1 = 3K3, R2 = 2K2 --> Rx = 2.00V
R1 = 3K3, R2 = 3K3 --> Rx = 2.50V
R1 = 2K2, R2 = 3K3 --> Rx = 3.00V
Keep reducing the voltage until your keystrokes are no longer echoed reliably.
PostPosted: October 28th, 2013, 2:37
after 1 month and counting only to determine if the terminal works or not, maybe it's better to know if the terminal will be of any aid in this case (simpler solution : look at a working system to see which p/n and release work).
Apple are picky without APPARENT reason.
PostPosted: October 28th, 2013, 5:28
Apologies for not replying earlier, for some reason I stopped getting thread reply notifications :( Came back just to make sure and what a nice surprise to see so many replies!
Spildit wrote:
Bits per second - 38400 Bits per second - 38400
Data bits - 8 Data bits - 8
Parity - None Parity - None
Stop Bits - 1 Stop Bits - 1
Flow Control - Hardware Flow Control - Hardware
Same thing as before - non-letter characters with the letter "z" echoed every now and then.
Spildit wrote:
Bits per second - 57600 Bits per second - 57600
Worse, instead of letter "z" I get random letters interleaved with non-letter characters.
With hardware flow control off I get the same result as above.
Nope, I purchased this drive from a computer shop, Apple was not involved... until I tried to put the drive in an Apple product that is :)
The USB-serial bridge IC can usually be programmed for 5V or 3.3V I/O, so I would try to jumper it for 3.3V, or 2.5V if available. You may be able to determine the input range of your USB-serial bridge by means of a potential divider in the loopback path.
Thank you for this suggestion, will pop in to an electronics store tomorrow to get the parts and try to at least discover the input range. The bridge I'm using is based on PL2303, whose datasheet does mention its ability to work with 5V, 3.3V or 3V signals. Will inspect the board to see what can be done (there's no configuration jumpers unfortunately).
I'd love to know that but as you can see at the beginning of the thread no-one was able to offer a definite conclusion ie. "yes it is possible" or "no not possible on this model". That's why I embarked on this little quest to check this myself... and so far am enjoying the ride as much as a possible outcome :)
Users browsing this forum: No registered users and 58 guests
