 Post subject: HDS5C3020ALA632 family
PostPosted: November 21st, 2013, 9:12
Hi
I have this HDD wich clicks.
I have checked heads and platters, they seem fine.
When connected to UDMA, it clicks but after a few moments it goes ready.
When I try to select the family, it doesn't recognize it?
This is a new family unsupported?
Can I try to disable heads, to see if I can get any files?
ACELab partner
 Post subject: Re: HDS5C3020ALA632 family
PostPosted: November 22nd, 2013, 12:11
I think PC3K is not yet supporting those families.
But you can add it manually if have the necessary info.
PostPosted: November 22nd, 2013, 15:34
Hi
It's a ARM utility family.
Case solved.
ACELab partner
PostPosted: November 23rd, 2013, 11:05
Nice.
So what was the issue with it?
PostPosted: November 25th, 2013, 15:11
I could edit NVRAM and disable the bad head.
ACELab partner
Users browsing this forum: Google [Bot] and 17 guests
