 Post subject: HDD Toshiba mk1059gsm firmware
PostPosted: December 12th, 2013, 4:46
Hi to all
Recently i'm playing with a rdx cartbridge that mount a sata disk model toshiba mk1059gsm
Taking a look to toshiba web page i can see that it's a normal hdd with a modified firmware for rdx use. Somebody have the original firmware for the disk?? I'm trying to convert the rdx in a normal disk othertime
 Post subject: Re: HDD Toshiba mk1059gsm firmware
PostPosted: December 12th, 2013, 20:32
What is with these cartridges that have a HDD inside? I got a new Dell Server with some RD1000 Cartridges. The RDX seem to be compatible with this system.
I did read something about these when I first got the server, but time and not wanting to mess with a production server hindered that.
If I get some time I will try and find the small amount I found on hacking these drives
PostPosted: December 13th, 2013, 4:37
I have one suspicious drive in stock. I will check, if I will be able to create backup with SD tool
PostPosted: December 13th, 2013, 4:42
model Toshiba MK1059GSM HDD2K11 F VL01 T
PostPosted: December 13th, 2013, 10:35
hi,
The exact model it's model Toshiba MK1059GSM HDD2K11 F VS01 T. Can you send me your firmware or backup??? (if it's a backup i need the name of tool to use it
i'm going to update the disk, and check the result... :P
Thanks a lot!!!!
PostPosted: December 13th, 2013, 17:30
Hello maschino,
models not match 100%. Your is VS01 T my backup is VL01 T
I don't have a lot of experienc with Toshiba.
!!!!!!!!!BEFORE YOU BRICK DRIVE!!!!!!!!!!!!!! Please ask for confirmation, if my backup Will work on your model
I use SD HD Doctor for Toshiba
mk1059gsm_hdd2k11_f_vl01t.zip [45.19 KiB]
Downloaded 1576 times
PostPosted: December 13th, 2013, 17:32
Hello maschino,
inform us about about further steps
PostPosted: December 14th, 2013, 9:05
i take a look to the zip file, and i dont know how can i do... i'm going to try with diferents tools, because i dont have the SD HD Doctor for Toshiba (i was waiting for a bin file or similar, to update firmware...)
If i get a brick drive, it's not a big problem... now i'm only try to learn something about
I'll inform you about my progress..
PostPosted: March 3rd, 2014, 7:31
Hello Maschino, have you solved the problem of firmware update on the MK1059GSM hard disk?
I have the same problem, and i need to solve it.
Bye
PostPosted: April 3rd, 2014, 14:58
i dont get anything... yet.
I don't have too much time to test.. and it's a parking project.... sorry
Users browsing this forum: No registered users and 47 guests
