 Post subject: Problem on seagate ST3000DM001(3TO)
PostPosted: January 26th, 2014, 15:15
Hello All,
I am new in this forum, this is a very nice forum and cool community.
I have a failure on my disk, i don't have access to my disk, my operating system recognizes my disk but i don't have access
to my partitions.
When i boot the disk i have 2 sounds and sometimes with a beep :
https://soundcloud.com/kerpox/disk-seagate-failure
Technical Information about my disk :
Device Model: ST3000DM001
Firmware Version: CC24
User Capacity: 137.438.952.960 bytes [137 GB]
Sector Size: 512 bytes logical/physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Jan 26 20:10:12 2014 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Thank you for your support.
Matt
 Post subject: Re: Problem on seagate ST3000DM001(3TO)
PostPosted: January 26th, 2014, 16:34
I'm afraid that's not a very pleasant noise. Your drive may suffer from some different problems. It stops spinning, doesn't it? (it is a bit hard to tell from the recording, since it seems that either you move away from the microphone or it does actually stop spinning). I would check for loads of dust in PCB contacts and give it a try, but almost certainly that's a scratch or heads issue - defenitely not a DIY. I wouldn't power it up even once more it data inside is important.
Cheers
PostPosted: January 27th, 2014, 13:48
Hello deftrue,
Thank you for your answer.
It is possible is a pcb problem or its is certainly a mechanical problem?
PostPosted: January 27th, 2014, 15:35
99% not a PCB issue.
PostPosted: January 27th, 2014, 18:13
Which is the method to find a root cause?
Thank you for your answers
PostPosted: January 28th, 2014, 0:20
Is this drive from an external? Or simply from a tower?
PostPosted: January 28th, 2014, 3:31
It is a external drive on usb case.
PostPosted: January 28th, 2014, 20:53
Could the external drive have sustained some sort of physical shock, e.g. dropping, while operating?
PostPosted: January 28th, 2014, 22:50
To me YES , the 2nd possibility is a head failure. They fail anytime anyway without warning...
PostPosted: February 2nd, 2014, 16:38
I have the exact same issue on the exact same drive.
Have you had any luck?
Users browsing this forum: No registered users and 186 guests
