 Post subject: FLASH software recovery
PostPosted: February 13th, 2014, 17:26
I search software for recovery data from dump nands. I have programmer for too many nands and nors. I dont need nand reader.
 Post subject: Re: FLASH software recovery
PostPosted: February 13th, 2014, 17:52
PC3K Flash or SoftCentre. You will need their readers in order for the software to work, but if your dumps are good, you should be able to import them into their programs.
PostPosted: February 13th, 2014, 19:35
Standard programmer usually reads nand flash wrong.
PostPosted: February 14th, 2014, 3:38
Yes, you need SA data too. Which contains block numbering, ECC data etc...
PostPosted: February 14th, 2014, 4:56
I have Wellon VP-996.
I have experience with Salvation Data Flash Doctor, but lot of nands cant to read.
PC3K Flash or SoftCentre which is better?
PostPosted: February 14th, 2014, 7:16
search the forum as this has been discussed already, and all posts are still relevant.
cheers
Users browsing this forum: Google Feedfetcher and 60 guests
