 Post subject: Buffalo with network(3TB)
PostPosted: March 15th, 2014, 12:58
Hi
I have Buffalo with network(3TB) .The HDD not appear in my pc .I used UFS Explorer pro. 5.11 I saw the files and folders , when I recovery any file or folder I got zero files size.
Pls any advice ?
 Post subject: Re: Buffalo with network(3TB)
PostPosted: March 15th, 2014, 16:19
Do you work with an external hard drive or a NAS from Buffalo?
How do you connect the device to your machine, so it "not appear in my pc .I used UFS Explorer pro. 5.11 I saw the files and folders , when I recovery any file or folder I got zero files size"?
Which diagnostics / DR tools you have?
PostPosted: March 15th, 2014, 16:26
Using net cable not work.
I opened from the box ,it is one hdd sata.
Pls your advice
Thank u
PostPosted: March 15th, 2014, 17:39
Have to run some tests on the drive to rule out the drive's hardware being the problem. For basic tests, look into MHDD.
PostPosted: March 15th, 2014, 17:46
Can you see the file system with Linux Reader for Windows (freeware)?
http://www.diskinternals.com/linux-reader/
Can you show us the contents of sector 0 (in hex)?
PostPosted: March 17th, 2014, 4:13
attached 2 files
Thank you
PostPosted: March 17th, 2014, 7:25
if you have pc3k, make a clone of your patient hard drive into a healthy same capacity hard drive
then put this clone hdd in the buffalo box and try connect to hard drive through network
Users browsing this forum: Google [Bot] and 36 guests
