Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST ST2000DM001 Stops spining
PostPosted: June 27th, 2014, 8:40
For starters, adjust the imaging parameters per drive's behavior.
PostPosted: June 27th, 2014, 10:20
i do it.
I can avoid problems with failed sectors making DE jump 8 sectors.
but otherwise is that the drive power down every 5 mins aprox. and i do not know why.
Any idea?
PostPosted: June 27th, 2014, 10:22
What does the error log say? There has to be an error regarding what the drive is going while imaging.
PostPosted: June 27th, 2014, 10:48
I' report Log here in 30 mins
So many Thanks Labtech
PostPosted: June 27th, 2014, 11:32
So sorry, now not sec errors reading, and not power down HDD
so sorry.
anyway; the drive can clone very slow and i can hear continous clicking sounds low volumne, i suppose HDD need to recalibrate continously.
anyway i atach DE log and Utility log
DE log:
->LBA = [ 410 718 513.. ], Step = 256
->LBA = [ 410 799 921.. 410 800 176], Step = 1 IO Error
->LBA = 410 800 112, Jump = 8
Software reset... Ok
<-LBA = [ 410 799 921.. 410 800 112], Step = 1
->LBA = [ 410 800 112.. ], Step = 256
->LBA= [ 410 800 112.. Skip Sectors
->LBA = [ 410 800 114.. ], Step = 256
->LBA = 410 814 962, Step = 256 [Drive is not ready!!!]
Software reset...
Hardware reset Ok
->LBA = [ 410 815 217.. ], Step = 256
->LBA = 411 761 137, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 761 392.. ], Step = 256
->LBA = 411 787 504, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 787 759.. ], Step = 256
->LBA = 411 840 751, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 841 006.. ], Step = 256
->LBA = 411 852 526, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 852 781.. ], Step = 256
->LBA = 411 867 117, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 867 372.. ], Step = 256
->LBA = 411 893 740, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 893 995.. ], Step = 256
->LBA = 411 920 107, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 920 362.. ], Step = 256
->LBA = 411 934 698, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 934 953.. ], Step = 256
->LBA = 411 946 729, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 946 984.. ], Step = 256
->LBA = 411 973 352, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 973 607.. ], Step = 256
->LBA = 411 987 943, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 988 198.. ], Step = 256
->LBA = 411 999 718, Step = 256 [Drive is not ready!!!]
->LBA = [ 411 999 973.. ], Step = 256
->LBA = 412 014 309, Step = 256 [Drive is not ready!!!]
->LBA = [ 412 014 564.. ], Step = 256
->LBA = 412 026 340, Step = 256 [Drive is not ready!!!]
Software reset...
Hardware reset Ok
->LBA = [ 412 026 595.. ], Step = 256
Utility Log: (if i read in DE using utility)
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Spin Up
SpinOK
SnapshotEventOccurred( SNAPSHOT_INITIAL_VALUES ).
(P) SATA Reset
(S) SATA Reset
(S) SATA Reset
(H) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
(S) SATA Reset
PostPosted: June 27th, 2014, 12:23
Finally Stoped
DE LOG
->LBA = 413 163 006, Step = 128 [Drive is not ready!!!]
Software reset...
Hardware reset Ok
->LBA = 413 175 037, Step = 128 [Drive is not ready!!!]
Software reset...
Hardware reset
Power OFF
Power ON
->LBA = 413 189 500, Step = 128 [Drive is not ready!!!]
Software reset...
Hardware reset
Power OFF
Power ON
Software reset...
Wait 25000 ms. Drive is not ready! Power OFF!
27/06/2014 18:02:15 - Execution of all processes is aborted!
PostPosted: June 27th, 2014, 12:24
The log only say: Drive not ready! Power OFF
PostPosted: June 27th, 2014, 14:34
There you go. The drive is very unstable, where it keeps trying to get readiness within 25000ms. When it gets there, the system powers it off, as it was set to do, unless that parameter is modified. Caution with that as that may not necessarily be a good idea.
Users browsing this forum: Majestic-12 [Bot] and 49 guests
