Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: WD Mybook Essential 1tb smoke
PostPosted: June 27th, 2014, 20:27
Hi 0383A
i answered you in PM.
If you have a little of soldering skill you can also try what "fzabkar" wrote.
Also, if you have soldering skill, i can send you those TVS diodes...
Consider that it's not sure that cutting diiodes (or replacing them) would fix the pcb because we still don't know if there are further damages on pcb components.
My firmware database:
PostPosted: June 30th, 2014, 2:51
loki wrote:
Dear Loki,
thank you for your link. Unfortunately Ebay tell me that you don't ship to my country!
Kind regards
0383A
PostPosted: July 9th, 2014, 10:38
Dear all,
A short update.
- New USB PCB received today, thank to Loki for his link I could get the part.
- SATA PCB on it's way to get the TVS diode 12V fixed
0383A
PostPosted: July 10th, 2014, 6:30
report us when you get the diodes Fixed.
Maybe you can access to data or maybe more work needed.
PostPosted: July 10th, 2014, 13:28
Hi hhddrec,
Michael Chiklis is taking care of my sata pcb and it's diodes. :D
0383A
PostPosted: July 10th, 2014, 14:37
i received your pcb today at 6:00 p.m.
Changed the shorted 12v diode, other diode and resistors are good, but your pcb don't work.
It gets very very very hot after 5 seconds since power on on RAM chip.
So probably this means that the RAM chip is shorted!
We need a new PCB.
PostPosted: July 10th, 2014, 17:04
Sorry, i had to unsolder the rom chip because it was impossible to read it from pcb.
The shorted ram prevents rom reading, after i unsoldered the rom i was able to read it with eprom.
ROM backup:
ROM.rar [179.38 KiB]
Downloaded 493 times
P.S.
RAM chip has also burn signs!
I read inside ROM some hdd infos:
WD10EADX-00TDHB0
FW: 77.04D77
PostPosted: July 11th, 2014, 7:50
0383A wrote:
Dear all,
A short update.
0383A
Hi Michael, looks that 0282A have donnor drive.
PostPosted: July 11th, 2014, 8:17
Hi hhddrec,
he didn't say that he has a donor drive, he told me that he got just a new sata/usb adapter (to decrypt data).
Now he needs a donor pcb for his drive which i shipped to him this morning.
P.S.
never happened to you that RAM chip got very hot with burn smelling after TVS diode swap?
This is what happened to his native pcb after i changed the 12v TVS, RAM chip fried after few seconds since i gave power to the pcb.
It was not just a TVS problem.
PostPosted: July 11th, 2014, 8:21
Sorry michael chiklis, and 0383A, you are on true.
0383A said:
"New USB PCB received today"
sorry was a mistaken.
PostPosted: July 17th, 2014, 1:59
Dear All,
here is a new update:
Thxs to Michael Chiklis, I received yesterday a new Sata PCB with a ROM copy from my original one. I installed the Sata PCB on the disk, connected to Sata PCB to a sata power cable and turned the computer on. I could hear the disk starting to spin. I let it like that during 10 minutes. No smoke, no heat, no burning smell. Turned everything off. Took the disk and installed the USB PCB on it. At this stage I wanted to re install the whole in it's case, but after a few attempts I abandoned the idea.
I plugged the power cable, then the usb cable. I heard again the disk starting to spin. Windows popup appeared with "new device found, starting initializing". Then error message came as Windows did not found the right driver for the device.
After that a popup from WDsmartware "WD quick view" appear with the red light blinking, it gives me the modell of the HD, the use of it, and temp. And there it mentions "hot"
If I open the WDsmartware software, it promps me for the pw. PW works, and I can see now all my data. But I still has another warning from WD Smartware. It mentions that "the HD has overheated, and that the drive will automatically shut down within 4 minutes in the case there is nothing to cool the drive. I have to deconnect the drive as soon as possible." Strange if I touch the disk, temperature is totally normal.
I will start to save my data on a new disk later today, and hope it won't shut down every 4 minutes.
thanks to all for your kind assistance
0383A
PostPosted: July 17th, 2014, 3:22
Congratulatioons 0383A!
if you can not get data contact another time here on forum.
PostPosted: July 17th, 2014, 3:56
Congratulations now just make sure you implement a good backup strategy. Its cheaper & less hassle than having to do data recovery :)
You could also look at Office365 Small Business http://office.microsoft.com/en-gb/busin ... 20365_text
The cheapest version now has 1Tb of cloud storage for £3.30 per user per month
Or if you want Office software included then £8.40 per user per month
Loki
PostPosted: July 17th, 2014, 6:19
So I started to save data, but it will take a long time to do. As after 4 minutes the drive cut his connection to the computer. Then I have to unplug wait the drive to be cooler, and plug it again. start again to copy.
And yes the drive get warm. Not hot, but warm. Should I use ice to cool it down? :)
Yes Loki, backup strategy has been changed in order to avoid in the future the same case. thx. We learn from our errors, isn't it?
0383A
PostPosted: July 17th, 2014, 6:31
Put cooler to mantain temp down.
there are Profesional tools for data recovery in thoses cases but are expensibe if you are not a pro.
PostPosted: July 17th, 2014, 6:40
Hi hhddrec,
thx for your reply
you mean a desk cooler I have in the office? or a cpu fan?
0383A
PostPosted: July 17th, 2014, 7:14
that you want
but as powerfull better.
PostPosted: July 17th, 2014, 7:20
Dyson is my friend :wink:
PostPosted: July 17th, 2014, 9:21
The drive got overheated by your old pcb due to shorted RAM chip, the high temperature issue was recorded in SMART status for this reason you still get overheat warnings.
The shorted RAM chip got very hot so the heat was transfered to the drive, maybe the drive got damaged due to the high temperature when it was attached to your bad pcb.
PostPosted: July 17th, 2014, 9:28
Hi Michael,
and by cooling it with the dyson will it help to keep the temp at an average level?
0383A
Users browsing this forum: No registered users and 254 guests
