 Post subject: [URGENT] parity in HP RAID 6 Case
PostPosted: August 28th, 2014, 14:21
Hello RAID gurus,
I have a case with an HP RAID 6.
There was 5 working drives and 4 defective drives. I was able to repair two of the defective drives.
So now I have 7 working drives out of 9. It should be enough to recover the data.
I was able to verify the type of RAID and find the order, the first drive, the block size and the delay.
So I have almost everything. My problem is with the parities. The first one is a simple XOR, just like in RAID 5 but I don't know (and can't find) how the second one is calculated and it doesn't seems to be Reed Solomon, because when I try that in R-Studio, it doesn't work as expected.
So, does someone knows (and/or is willing to give me a hint) how the second parity is calculated in HP RAID 6 ?
Lemmy
 Post subject: HP RAID 6 recovery
PostPosted: August 28th, 2014, 18:15
There was 5 working drives and 4 defective drives...
Please check your PM.
 Post subject: Re: [URGENT] parity in HP RAID 6 Case
PostPosted: August 29th, 2014, 5:31
Dr.Kiev is the Best person to Contact about ALL Types of Raid Cases ...
PostPosted: August 29th, 2014, 15:55
Case close.
Thank for your PM...
Lemmy
PostPosted: September 1st, 2014, 8:46
can you report us recipe?
PostPosted: September 8th, 2014, 6:01
The controler was not dead... And *it* knows how to rebuild with 2 missing disks
Lemmy
PostPosted: September 8th, 2014, 8:14
thanks Ici Lemmy
Users browsing this forum: michael chiklis and 230 guests
