 Post subject: copy 1tb external hdd to 2tb external hdd with hddguru?
PostPosted: September 21st, 2014, 23:43
Hi, Can I copy a 1tb external hdd to a 2tb external hdd and still use the remaining 1tb on the target 2gb hdd?
Via USB ports... Thanks, Len
 Post subject: Re: copy 1tb external hdd to 2tb external hdd with hddguru?
PostPosted: September 22nd, 2014, 2:27
if 2 drives are ok. there in no priblem to continue using them
PostPosted: September 22nd, 2014, 8:34
The word "copy" is too generic to understand what you are trying to accomplish and thus providing advice.
What exactly are you trying to do?
PostPosted: September 22nd, 2014, 8:58
You could copy the 1TB partition to the 2TB, make another partition with remaing space and have 2 drive letters for the drive
or yould just copy off the stuff from the 1 TB to the 2TB and use the remaining space but that seems so obvious I think it is not what you mean.
Do you mean "clone" or "restore the 1TB image to the 2TB drive" ?
PostPosted: September 22nd, 2014, 9:34
If you are referring to coping a healthy drive to another it will work. My preference is to use software such as Paragon http://www.paragon-software.com/products/home/ so I can expand or contract partitions to fit new drive as needed. Drives with problems are not addressed with this type of product.
PostPosted: September 22nd, 2014, 9:36
if you will copy, then you can use remaining space on your 2TB drive.
if you will image drive, there are more scenarios
- you can image to new drive 1TB to 1TB and on remaining space you create new partition, or use software to partitioning from 1TB to 2TB
- or image from 1TB directly to 2TB partition
Users browsing this forum: Majestic-12 [Bot], Pi0tR and 55 guests
