 Post subject:
PostPosted: April 24th, 2004, 10:48
Hi everyone (again) ;)
A quick question about hdd access methods for you brainers: :cool:
When mhdd or pc3k detects a bad sector, they detect an lba sector, correct? If so, this means that all 512 bytes in that sector become marked as bad.
Is there a way to read just the good bytes inside the 512 sector and discard the bad ones? Or hdd access protocol (ata) does not allow reading/writing of less than 512 bytes?
Thanks to all
Regards,
-=pc3krules=-
 Post subject:
PostPosted: April 25th, 2004, 15:54
I am a noobie so don't put too much stock in what i say now!
From my research, the whole sector is bad, unless you were grouping sectors together like some old and hush hush OS's, say 1024 or 2048 sectors, then i think it would work.
My research can conflict each other, at times. I read that the sector is dead forever, and other reading say it is a data issue and once the data is cleared it is ok, then why the read errors?
Well i have typed enough, i will crawl back into my little hole.
ME!
Users browsing this forum: Google [Bot] and 232 guests
