 Post subject: ST500DM002 terminal output
PostPosted: November 14th, 2014, 2:55
I have ST500DM002 Sata hdd. Hdd spins smoothly without any noise and spin down. I have try to access the terminal it shows the error....
Spin Up[0x00000000][0x00000000]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
FAIL Servo Op=0155 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000A
RECOV Servo Op=0055 Resp=0005x[0x00025CB4][0x00025CB4]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
FAIL Servo Op=0055 Resp=0007
RECOV Servo Op=0155 Resp=0005x[0x0000B319][0x0000B319]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
RECOV Servo Op=0055 Resp=0005x[0x00030FCD][0x00030FCD]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
After shorting pin points hdd showing it size 3.86 GB
So help us to access the data of the hdd......
 Post subject: Re: ST500DM002 terminal output
PostPosted: November 14th, 2014, 3:08
Looks like suspect heads to me.
PostPosted: November 18th, 2014, 22:03
Author,which type command line do you get the firmware info?
PostPosted: November 19th, 2014, 1:33
Seagate Barracuda ST3500DM002
F/W=KC48
P/N=1BD142-303
Date code=13485
Made in Thailand
PostPosted: November 20th, 2014, 1:10
F/W=KC48
P/N=1BD142-303
Date code=13485
Made in Thailand
Author,I am sorry and give you a wrong meanI want to know your information of TTL adopter.such as chip type.etc.
PostPosted: November 20th, 2014, 14:18
+1
PostPosted: November 26th, 2015, 18:39
data-medics wrote:
+1
No. i had same error.
then i short two pins and press ctrl+z
F3 T> came..
but timing is very important..
i try at least 20 times. it was very hard.
but all my data came.
Users browsing this forum: napalm_atx and 279 guests
