 Post subject: USB Port Toshiba Hard Drive
PostPosted: December 16th, 2014, 19:19
Dear all,
I've a unit of 2.5' USB port Toshiba hard drive, the front part of the disk (0% - 14%) is having massive of unread sectors, but the the rest are running smooth (right after 14%)
Was thinking to try out with compatible SATA PCB and run the imaging in Deepspar but then I realized that's no ROM chip on the board.
What other option(s) do I have for this hard drive? I've Deepspar and DFL-DDL
Thanks in advance
 Post subject: Re: USB Port Toshiba Hard Drive
PostPosted: December 16th, 2014, 19:30
Hi all,
A forumer named 'cmcraeslo' mentioned the IC606 is the ROM chip in viewtopic.php?f=1&t=26163&hilit=usb+port+toshiba&start=20, it looks like it is the ROM chip.
Will give it a try
PostPosted: December 16th, 2014, 21:06
In that thread, there is a post that shows the USB board and the SATA board side by side (http://prntscr.com/5hoxxw). You can see that IC606 appears only on the USB board whereas IC602 appears on both. I believe IC602 is your ROM and IC606 is for the USB-SATA bridge.
PostPosted: December 17th, 2014, 2:05
Hi Larry,
Now that's interesting. I didn't even notice that...
I'm searching for the donor SATA PCB, will see how it goes later.
Thanks again, Larry
Best regards,
Darecom
PostPosted: December 17th, 2014, 9:07
Why not convert to SATA Straight
PostPosted: December 17th, 2014, 11:14
Hi ROb,
Do you know the compatible SATA PCB that I should looking for?
Thanks in advance.
Best Regards,
Darecom
PostPosted: December 17th, 2014, 11:33
Look Again please ROb has marked the sata connections for you in his Picture :)
Digitalsupport
daRecoM wrote:
Hi ROb,
Thanks in advance.
Best Regards,
Darecom
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 17th, 2014, 16:14
Do you guys know if these use any type of encryption like the Passports do? I've yet to have one like this show up for recovery, but I know it's bound to happen sooner or later.
PostPosted: December 18th, 2014, 2:09
Hi ROb,
Thanks in advance.
Best Regards,
Darecom
No this one does not have any encryption for sure.
You can also search for more threads in this forum ( Specially Western Digital ) about how to convert it to SATA just to gain more confidence.
I have marked the points for you.
Need further help PM
PostPosted: December 18th, 2014, 6:12
Yes, these don't carry encryption.
PostPosted: December 23rd, 2014, 5:30
Try FKN8LD.
PostPosted: September 18th, 2015, 9:19
Jared ,
Did You Get Any i Got One Today Always Busy .Will Be Posting In The Forums For That Case :mrgreen: .BTW i Am Still WAiting for More Neat Tips And Tricks In PC3k On Your Youtube Channel Always Good To Learn New Stuff
Users browsing this forum: No registered users and 241 guests
