 Post subject: WD RED 4TB - WD40EFRX slow speed
PostPosted: January 18th, 2015, 10:15
Image Image Image
 Post subject: Re: WD RED 4TB - WD40EFRX slow speed
PostPosted: January 18th, 2015, 10:35
IM getting this slow speeds while copying new files that where created yesterday on this drive after download
The old files first 2TB copied the last month are copied without any speed problems to other HDD os my system with 100 - 120MB/s speed
if i try the same files i get usb 2.0 speeds or even lower
the drive itself doesnt have any bad sectors
what do you think guys ? what can i do ?
Smart:
Hdtune:
it could be antivirus process but i dont notice anything while copying from the other parts of the disk...
wierd
thanks guys
PostPosted: January 18th, 2015, 11:12
are you using any utility for copying ?
Data Recovery Pakistan
PostPosted: January 18th, 2015, 11:25
i was using windows explorer only
this happens on teracopy too ( could be windows copying issue but it seems worse than that)
Copying from hard drive to my SSD (both internal sata ports) with antivirus disabled
Now for example the other part of the hard drive that i was talking about ( the same hard drive to the same ssd) old data
thanks for trying to help
PostPosted: January 18th, 2015, 17:15
new files that where written today have this slow read issue as well
maybe its the writing head i don't know
im backing up the data
PostPosted: January 19th, 2015, 5:16
it seems you are struggling with the same NAS drives ?
viewtopic.php?f=1&t=28825&start=60
PostPosted: January 19th, 2015, 8:46
its not the same thing mate :)
that drives that you have seen on that old post were 2TB reds that where sent to WD after the recovery (some bug on NAS) after firmware upgrade make me lost the partition
in this case is one new 4TB Red :)
PostPosted: January 19th, 2015, 12:39
you are right, sorry.
RED confuses me because they are for NAS, so you are using this as desktop hdd right ?
one of many reason could be that drive has some slow sectors, the reallocated sector count value is high.
you should immediately backup all your data
after that you can scan your drive using MHDD for full surface verification
PostPosted: January 19th, 2015, 20:55
Doesnt have any bad sectors as of today
Yes you are correct im using as a normal desktop Hdd... they are very good hdds and i cant hear them running :)
I remenbered to create 4 partitions on the hard drive... 900Gb each
Will try to discover if one of the plates is bad
Thank you for your input
Users browsing this forum: No registered users and 353 guests
