 Post subject: Head magnets on the platters
PostPosted: January 9th, 2015, 3:17
I have opend a WD800VE drive (IDE) and found that the heads are stuck on the platter and the magnets of the third and fourth heads are detached from heads and stuck on the platter in another place.
I could remove the magnet on the top by using a tweezers but with difficulty.
Is there a technique how to remove the magnet of the botton?
Thank you for your help.
 Post subject: Re: Head magnets on the platters
PostPosted: January 9th, 2015, 11:52
Here is a photo of the top platter.
PostPosted: January 10th, 2015, 10:34
There are really no "methods" to removing the head sliders from the platters. But i would avoid removing them with any tool as your probably going to risk scratching the platters.
I would try heating the area with a heat gun (very low heat) with the HDD on its side. If it works they should just fall off the platters. I know heat isn't the best thing for platters but you don't have many options.
Web: https://www.day1data.de
PostPosted: January 12th, 2015, 13:21
Thank you for your reply.
But if I change the heads without removing the magnet from the surface, it will not work as the new magnet will hit the one on the platter.
PostPosted: January 12th, 2015, 13:27
Its a head, not a magnet, for some reason its stuck to the platter due to stictation. Using a heat gun to warm the platter and magnet might make it loose. Again, strange how that happened the head must have been forced of the arm. Was the drive open in a clean room? It looks like there is dust on the platters, but that could be the image.
PostPosted: January 13th, 2015, 5:44
HI,
Twizzlers can Damage platters use paper to Remove it.
PostPosted: January 14th, 2015, 15:14
When I opened the drive in a clean room I found the magnet in that position. the head also is stuck (on the right).
the problem is not with the magnet on the top. I could remove it with tweezers . The problem is with the magnet on the bottom.
PostPosted: January 14th, 2015, 18:37
Those are NOT magnets...as stated before, it's the head (slider). If you have a plastic drinking straw you can flatten it and use it to remove the head on surface 0.
http://www.rescue-it.se
PostPosted: January 18th, 2015, 12:38
no it's the magnet. When I tried to remove the top one, it's very resistant and and can't be removed easily.
PostPosted: January 18th, 2015, 14:52
No, again. They are NOT magnets, they sliders and become stuck to the platter due to "stiction".
PostPosted: January 18th, 2015, 16:36
Have a look at a hard drive break-out here: http://hddscan.com/doc/HDD_from_inside.html
This is a slider: http://prntscr.com/5u4d13
This is a magnet: http://prntscr.com/5u4dj7
Now, which is it you are having difficulty removing?
PostPosted: January 18th, 2015, 17:28
The drive need to be disassembled
PostPosted: January 19th, 2015, 3:42
Yes, I have done this on many occasions. In fact only last week we had a WD3200BEVT in with all four sliders snapped off and stuck to the platters.
Tricky, but not as tricky as a 3-platter 1tb portable :-)
Never had to perform this operation (yet) on a 4-platter Shrek drive, but not looking forward to it!!!
PostPosted: January 19th, 2015, 7:20
Possible without disassembling.
Lower part of the disk to the spindle in the cleaning solution from 3M for example.
Sliders themselves fall.
PostPosted: January 19th, 2015, 11:26
Thank you all for your help.
I didn't ment the big magnet. I thought that the slider also is a peice of magnet :)
Tomset, pleae could you expalain more? what is "the cleaning solution from 3M"?
PostPosted: January 21st, 2015, 3:58
http://solutions.3m.com/wps/portal/3M/e ... skDrives/#
PostPosted: January 21st, 2015, 4:17
Anyone know where I can buy this stuff in the UK?
I've tried many times to locate a seller here, but never found one :-(
PostPosted: January 21st, 2015, 7:45
In stores this does not happen.
Used only in the workplace.
Must be ordered through your local 3M.
For yet it is not available in some countries. As high-tech.
In UK, I think comes.
PostPosted: January 21st, 2015, 9:46
on 3m website: support-->where to buy
They have offices everywhere, even in our little country town
PostPosted: January 22nd, 2015, 6:13
not DIY.
Users browsing this forum: No registered users and 67 guests
