Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: nice article on NAND Flash RE/hacking
PostPosted: January 14th, 2015, 4:24
I changed all the capacitors 1000µF/6.3V, and the monitor is working again. :mrgreen:
I tested the old ssd, and it really died. If I have time, I will test the nand reader with it.
PostPosted: January 14th, 2015, 9:16
Nice!
If you didn't want the old SSD, I would consider buying it from you for research purposes. I can send you any data recovered if that's any help as well.
PostPosted: January 15th, 2015, 18:21
I cloned the new ssd, so I no longer need the old. I can give it to you, but I notice that the pcb was slightly damaged in one corner. You need only the nand flash?
PostPosted: January 15th, 2015, 20:29
The complete thing would be ideal, it doesn't matter if there is some slight damage. I can send you some funds for postage.
Thank you :)
PostPosted: January 20th, 2015, 7:15
I sent you a private message last week. :wink:
Users browsing this forum: No registered users and 114 guests
