 Post subject: PC-3000 Scripts
PostPosted: February 12th, 2015, 8:39
Is there a database of scripts somewhere?
Is there a manual?
I would like to make a script that when coping via map of folder or files, if a BS is encountered the reading of the current file stops and skips to reading the sectors of the next file.
can someone help me with that?
thank you,
 Post subject: Re: PC-3000 Scripts
PostPosted: February 12th, 2015, 15:55
DE already has this option when you do "Save files." I think the option is "Skip files on bad sectors" or "skip incomplete files" or something similar (I forget the exact wording). You have the option to save them to another folder (which we do, so we can send customers a listing of all "good" and "problem" files).
PostPosted: February 12th, 2015, 16:06
Yes, DE does this well.
What I do is make a map to select the sectors pertaining to selected files, then clone them with option "skip chain on error" selected. Then select "use copy only" and save the files with the option to save files with unread sectors in a "!problem" folder.
PostPosted: February 13th, 2015, 9:40
amazing! thank you i will give it a try!
but still, is there a database of scripts? maybe someone made a nice script that can be useful for someone else. it would have been nice if there was a place to upload and browse scripts...
PostPosted: February 13th, 2015, 16:48
I think this is a feature that few if anyone has ever really used. The time you'd spend trying to figure out how to even write a custom script is unlikely to be worthwhile. Especially when other tools such as DDI can do a better job imaging.
PostPosted: February 20th, 2015, 12:03
Off the beaten track a little but same subject. Is there a facility in the DDI DRE to do the same thing? I have just got the network add-on for my DDI's so its still new to me. I think its available in the Ops Server, but how about DRE?
