 Post subject: send the correct codes using MHDD
PostPosted: February 26th, 2015, 8:35
Regards Hello .
I wonder how I do to send the correct codes using MHDD , to recover a hard drive intel ssd 520 series 480GB passwords .
The disc is locked by password .
I would like to learn as what the code in hexagedecimal , to be used in a script.
Thank You !!
 Post subject: Re: send the correct codes using MHDD
PostPosted: February 26th, 2015, 12:35
I believe that's a hardware password encryption lock. Its not something as simple as viewing it in hex.
PostPosted: February 26th, 2015, 16:50
If the data are not important, then some SSDs can be "crypto erased" using the PSID key on the label.
PostPosted: February 26th, 2015, 20:26
Thanks for responding.
fzabkar , could you explain a little more about your answer please , do not really matter data .
I am a novice in the field and some things really do not understand at all.
Thank You!
PostPosted: February 26th, 2015, 22:52
I don't know whether yours is one of these, but some SSDs which incorporate hardware encryption can be instantly secure erased or cryptographically erased by entering their PSID key (Physical Security ID) into the appropriate tool. The drive's unique PSID is printed on the label.
PostPosted: February 27th, 2015, 8:41
Well after some reading I've tried some tools do but it has not worked . the only tool that has detected my ssd has been MHDD , but still I could not do anything because I do not have the user key or the teacher. dd is a 480GB Intel SSD 520 Series
Users browsing this forum: Ahmed Saeed, Google [Bot] and 133 guests
