 Post subject: HD Seagate Firmware problem, LED
PostPosted: February 27th, 2015, 12:08
Hello everybody!
First of all let me give thanks to every useR who shares his knñowledge in this forum
I have a case with a Seagate Barracuda es.2 with an LED error. I have tried in every way to solve this problem with pc3000 Both methods with no succes.
This is the drive :
Could you guys share some ligth in this case please.
Regard to you all
 Post subject: Re: HD Seagate Firmware problem, LED
PostPosted: February 27th, 2015, 18:05
"LED error" ?
Too vague
PostPosted: March 2nd, 2015, 3:55
Sorry about that...
F3 T>
LED:000000CC FAddr:0024BF31
PostPosted: March 2nd, 2015, 5:46
Research for BUSY FIX on this forum.
PostPosted: March 2nd, 2015, 11:47
Spildit wrote:
Ok.
Instead of using pc3k fix it by hand as explained here :
http://www.hddoracle.com/viewtopic.php?f=83&t=38
best regards.
This methods require terminal access witch i don't have
PostPosted: March 2nd, 2015, 12:11
The solution was a short circuit after the first spin up. It toked a few tries but at the end the drive reached ready state and after everything was easier.
Thank you all
