 Post subject: WD Firmware request 30078
PostPosted: April 15th, 2015, 8:52
Hello there,
Please I'd appreciate if somebody could share a firmware for the following drive (need loader):
Man.: WD
Model: WD10JMVW
FW version: 00030078
Thank you very much.
 Post subject: Re: WD Firmware request 30078
PostPosted: April 15th, 2015, 9:03
Full model and family please.
PostPosted: April 15th, 2015, 9:07
Sorry, the family is 11S5XS0 (that also completes the model). Can't find a FW match in hddguru files...
Cheers.
PostPosted: April 15th, 2015, 9:32
deftrue wrote:
Man.: WD
Model: WD10JMVW
probably a Firebird family,
RAID/Server Recovery
PostPosted: April 15th, 2015, 9:37
Yes, definitely is Firebird. Looks like I had one with that FW here before as a heads donor, but apparently I never backed up the modules/tracks. I only backed up the ROM. Too bad.
PostPosted: April 15th, 2015, 10:01
Yep, it's a Firebird - or at least, the PCB is recognized as such.
Cheers
PostPosted: April 15th, 2015, 10:05
You're welcome...
Mikippp
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 03.78C
>ROM generation.......................... : 03.79C
>Link table version...................... : TP.4D.
>Consolidated ROM version................ : 00030078
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 73 266
>SA regions address...................... : by default
>SA Translator loading................... : Ok
!SA defects assigned..................... : 3
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 00030078
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1,Copy 2,Copy 3
ROM.zip [648.67 KiB]
Downloaded 350 times
PostPosted: April 15th, 2015, 10:17
Mikippp wrote:
You're welcome...
Mikippp
>Techno mode key
>RAM:
>ROM:
>ROM Modules:
>Service area:
Thank you very much :wink:
Users browsing this forum: Google [Bot], unknown and 170 guests
