 Post subject: What software use to see HDD Serial Number?
PostPosted: April 17th, 2015, 8:39
Hello there,
Whats software use to see HDD Serial Number and other Informations.
like Manufacture Serial Number, Device ID etc...
Thanks ..
 Post subject: What software use to check HDD Serial Number and other info?
PostPosted: April 17th, 2015, 8:46
http://hddscan.com/ will definitely show more than just S/N.
 Post subject: Re: What software use to see HDD Serial Number?
PostPosted: April 17th, 2015, 15:12
If you are on windows and the drive is functioning correctly you can use 'wmic diskdrive get serialnumber' from command line. Alternatively you can usually see hdd serial numbers in the BIOS or by looking at the physical drive itself.
Users browsing this forum: No registered users and 102 guests
