 Post subject: WD3200AAJS - 2 Units same problem ..
PostPosted: May 1st, 2015, 10:33
Hello there,
I am new on this and I get interested on this Field,
Now my friend gave me defect Hard Drive, WD3200AAJS Bios Detected but 0.0gb
in Computer Management it also detect but it has " ! " ... I like to bring this HArd Drive to life ..
and also This is my step to learn. I already Backup the ROM ...
Thanks ...
 Post subject: Re: WD3200AAJS - 2 Units same problem ..
PostPosted: May 1st, 2015, 10:43
Hello there ,,
Thanks for your quick reply ..
No Clicking on the Disk ..
as of now only WD MARVEL only ..
I attach the 1 ROM ..
Thanks a lot ..
File comment: AAJS
WD3200AAJS ROM Dump PM25LD020 Willy.rar [181.69 KiB]
Downloaded 729 times
PostPosted: May 1st, 2015, 13:22
I'm not certain, but ISTM that PUIS is enabled (somewhere in offsets 0x28 - 0x29).
00000000  52 4F 59 4C 04 00 1E 00 0D 00 01 00 AF EA 39 5C  ROYL........¯ê9\
00000010  30 30 30 31 30 30 30 30 00 00 00 00 00 00 00 01  00010000........
00000020  30 31 2E 30 33 45 30 31 02 01 03 00 00 00 50 01  01.03E01......P.
00000030  4E E0 57 AF FC 2A 00 01 FE FF 00 00 00 00 00 00
00000040  01 01 01 00 00 00 20 20 20 20 20 20 20 20 20 20
00000050  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000060  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000070  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000080  20 20 00 00
See viewtopic.php?t=31078&p=215255#p215255
PostPosted: May 1st, 2015, 14:39
Spildit wrote:
Does the drive spin at all ?
I agree with fzabkar.
If the drive doesn't spin at all start by using something like HDAT2 to wake up the drive and disable PUIS.
I am now booting the other pc to do ..
while I am reading about HDAT2.. on how to do it .. :D
Learn and Learn ... :lol:
Thanks .. I will update
PostPosted: May 1st, 2015, 16:15
Hello mate,
Yes no spinning both drive..
I try HDAT2. no luck ... it errors.
I am now moving for GURU script.. from this thread ...
viewtopic.php?t=20208&start=
now I am downloading Linux mint for the shafoo trick..
PostPosted: May 1st, 2015, 16:21
If PUIS is enabled, then the drive should still spin up when it receives a read or write command, or when it receives and appropriate Set Features subcommand.
Can you show us an Identify Device dump from CrystalDiskInfo? If the drive is PUIS mode, then bit #2 of word #0 should report "Response incomplete". Word #2 defines the conditions for spin-up.
If bit 2 of word 0 is set to one, then the content of the IDENTIFY DEVICE data is incomplete. This may occur if the device supports the Power-up in Standby feature set and required data is contained on the device media.
The content of IDENTIFY DEVICE data word 0 and word 2 shall be valid.
PostPosted: May 1st, 2015, 17:45
Pcb on that model can have problems...is it 701444? If so move Rom to a new pcb-board.
http://www.rescue-it.se
PostPosted: May 1st, 2015, 20:17
No sir,
It is 701590 ....
Thanks ..
PostPosted: May 1st, 2015, 21:17
In MHDD ... There is
" WARNING : THIS DRIVE IS LOCKED BY ATA PASSWORD "
No Serial Number and No FW:
and I try the GURU script and
" ERROR: drive reports error "
PostPosted: May 1st, 2015, 22:08
Use HDAT2 to retrieve the drive's Identify Device report, eg ...
HDAT2 v4.7.1 (c) 2009 CBL  02.05.2015 05:51:13.064
Dump IDENTIFY DEVICE [HL-DT-ST DVDRAM GSA-4040B]
       00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F   0123456789ABCDEF
     Ú--------------------------------------------------------------------¿
0000 ³ C0 85 00 00 00 00 00 00 00 00 00 00 00 00 00 00   À….............. ³
0001 ³ 00 00 00 00 32 4B 33 38 55 37 35 47 32 31 20 38   ....2K38U75G21 8 ³
0002 ³ 20 20 20 20 20 20 20 20 00 00 00 00 00 00 33 41           ......3A ³
0003 ³ 34 30 20 20 20 20 4C 48 44 2D 2D 54 54 53 44 20   40    LHD--TTSD  ³
0004 ³ 44 56 41 52 20 4D 53 47 2D 41 30 34 30 34 20 42   DVAR MSG-A0404 B ³
0005 ³ 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 00                 .. ³
0006 ³ 00 00 00 0F 00 00 00 00 00 00 06 00 00 00 00 00   .............. ³
0007 ³ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 04   .............. ³
0008 ³ 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00   .x.x.x.x....... ³
0009 ³ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................ ³
000A ³ 3C 00 00 00 1C 42 00 00 00 00 00 00 00 00 00 00   <...B.......... ³
000B ³ 07 00 00 00 00 00 00 00 00 00 00 6F 00 00 00 00   ..........o.... ³
000C ³ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................ ³
000D ³ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................ ³
000E ³ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................ ³
000F ³ 00 00 00 00 00 00 00 00 00 00 00 00 00 F8 00 00   .............ø.. ³
I'm betting that many of the numbers will be 0xFF.
Users browsing this forum: Google [Bot] and 159 guests
