 Post subject: WD Data LifeGuard Diagnostics
PostPosted: June 22nd, 2015, 6:31
i have a couple of WD 2TB Red drives that i want to do extended tests on. The program tells me to close all programs that have files open on the drive being tested. But is it ok to still have Windows Explorer running? as i still want to be able to do other things while the test is being run.. est time to do the test is about 3hr 40m. was expecting longer as it took longer than that to do a full format.
 Post subject: Re: WD Data LifeGuard Diagnostics
PostPosted: June 24th, 2015, 2:58
Never used it, but would guess the program measures block response time, therefore the suggestion to avoid other disk activity, which can be misinterpreted as slow LBA.
For extended testing I'd suggest to go with HDDScan, which at least can do the same, but will show detailed results down to single LBA instead of a progress bar and a general conclusion afterwards.
Should you decide to look deeper into some (seemingly?) problematic area, you can re-scan it by defining a range instead of the whole drive analysis:
http://hddscan.com/
PostPosted: June 24th, 2015, 6:24
in addition to Dmitri
i would say, is recommended to these kind of tests in pure dos
PostPosted: June 26th, 2015, 1:07
jermy wrote:
pure dos
leeuk wrote:
2TB
I didn't test myself, but unsure that each and every DOS utility handles large drives properly.
Generally I believe that connecting new drive as a secondary one and launching HDDScan as an only program after reboot should be enough for a regular user.
PostPosted: June 26th, 2015, 1:21
you right, didn't noticed that it's 2TB
Users browsing this forum: No registered users and 243 guests
