 Post subject: i need help for ST31000528AS
PostPosted: June 29th, 2015, 4:45
Model: ST31000528AS
Pcb: 100574451 REVB
i need to find short points on pcb. any advice pls.
Best Regards
 Post subject: Re: i need help for ST31000528AS
PostPosted: June 29th, 2015, 8:49
Tip: How to identify the Read Channel test points:
http://www.hddoracle.com/viewtopic.php?f=24&t=123&p=149
PostPosted: June 29th, 2015, 9:03
Why would you need it for this drive model?
PostPosted: June 29th, 2015, 9:42
Thanks @jermy
it was my donor disc. Actually drive was good before (tested) head swap to patient disc. when head swaped to patient disc that has been given same error. (11 click and spin down) however i've swapped head to my donor disc again. Now my donor is giving same error like patient disc.
Terminal says:
Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
No HOST FIS-ReadyStatusFlags 2002B001
PostPosted: June 29th, 2015, 12:00
Most likely heads died on media damage somewhere in your patient drive.
PostPosted: June 30th, 2015, 8:29
I'm looking for new donor disc.
i'm not sure if found new donor asap, patient disc will be ok.
Users browsing this forum: No registered users and 32 guests
