 Post subject: Seagate 2TB ST2000DL001 FW CC96 / Sim Error 1009
PostPosted: August 24th, 2012, 11:06
I've had drives with similar issues as this, but never this specific error. Originally the drive had no access at all, it was a continuous BSY state and did not show up in the BIOS. This is what the Terminal output looked like:
Rst 0x40M
RW: Disc Ctlr Initialization Completed.
(P) SATA Reset
SIM Error 1009
RW Error 00000080
Then below that, it had something to the effect, Hi Temp or exceeded maximum temperature, something like that. I should have done a screen cap, but I was pretty sure it was PCB related.
I swapped the PCB and ROM, and the drive was able to be fully recognized, and become ready but it would time out on every sector.
Back in Terminal I get the same thing still:
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
But that's it, it just hangs there and doesn't go any further, and the temperature error is no longer present. Again, this drive is now recognized by every computer that it is connected to, and in DDI it gives you the full model and LBA count, but you just have no ability to read any sectors. Kind of like a translator issue on a WD.
Any ideas on this? Please feel free to PM. There's not much information out there with this specific issue. Thanks.
 Post subject: Re: Seagate 2TB ST2000DL001 FW CC96 / Sim Error 1009
PostPosted: August 24th, 2012, 12:05
Have you checked defect lists?
Tried to clear smart or translator regen?
PostPosted: August 24th, 2012, 15:30
I cleared SMART.
I sent a PM.
PostPosted: July 8th, 2015, 2:28
i have 4 disk that have same problem..
How can i repair it? is there any command or method except
"http://www.dolphindatalab.com/one-click-to-fix-seagate-sim-error-1009-by-dfl-ddp/"
PostPosted: July 8th, 2015, 5:04
or how can i repair or change 17a and 133 sys file?
http://ts.acelaboratory.com/index.php?/ ... a-sys-file
Could Sediv or Seagate Tools help us?
PostPosted: July 8th, 2015, 15:09
Did you try to read the two sys files using the F3 terminal commands in the Ace Lab tutorial?
PostPosted: July 8th, 2015, 15:35
How could it be?
i check 17a sys file via "F3 T>r17a"
then i get "DiagError 0000000E" message
obviously r17a file was corrupted.
is there any command for read or write this file?
Rst 0x10M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
If you try to read sectors terminal showing:
LED:000000BD FAddr:0000602B
You should try to find damaged FID in System Files. It could be 133 and 17a. To check 17a sys.file use terminal command:
F3 T>r17a
If you get message DiagError 0000000E, then this sys. file is damage and you need to fix it.
PostPosted: July 8th, 2015, 15:47
the solution is here
PostPosted: July 8th, 2015, 15:54
jermy wrote:
http://ts.acelaboratory.com/index.php?/Knowledgebase/Article/View/23/0/sim-error-1009-rw-error-00000080-17a-sys-file
we know that..
but i don't know how program or command solve this issue without any payment.
this is logical error.
PostPosted: July 8th, 2015, 15:59
sorry my friend
on this planet everything except for air and rocks is gonna cost you
PostPosted: July 12th, 2015, 8:24
jermy wrote:
sorry my friend
is this for reason Englishman want to say "cost of earth" instead of very expensive. :P
it is a easy problem. we don't pay to everything.... i.e. training.
PostPosted: December 27th, 2015, 5:41
r-read
w- write
i read some files from proper same model hard drive. with " r17A" "r133" "r28" "r35"
and after "w" it. w17A, .......
i use Hyperterminal's Y-modem..
http://forum.ru-board.com/topic.cgi?for ... start=1180
PostPosted: December 27th, 2015, 18:25
if the file is greater than 1 mb USB driver could halt and you'll see blue screen and restart.
You must use USB-TTL adapter.
DKU-5 cable is inefficient.
PostPosted: December 29th, 2015, 16:56
Thanks..
and you can see, correct, modify this binary files with some Hex Editor programs.
i.e Hex Editor Neo
PostPosted: February 5th, 2016, 22:11
FYI, not all F3 drives support these commands, mainly the older ones (Moose, Brinks, Wyatt, Holliday perhaps some others as well).
Users browsing this forum: Google [Bot] and 81 guests
