 Post subject:
PostPosted: December 14th, 2004, 23:02
who can tell me how to use it?
when I use it, It always let me enter USER password, but these hard disk don't have password, what is it mean?
I try to set a password for a HD, but when I use fasterase again, I type the password that I set, It faild. why?
Posted 15/12/2004, 22:58:
non one can tell me? include the author of the MHDD soft?
 Post subject:
PostPosted: December 15th, 2004, 17:21
do you try
set password>>>>>>then command fast erase? It's ATA standard SECURITY FORMAT UNIT.. If you have ATA command executor you can do this yourself :o
format prepare
Security format unit
check ATA spec
 Post subject:
PostPosted: December 15th, 2004, 23:24
You didn't replay my question. if it need I try it my self, I think I don't need access here to get some help.
sorry in my poor english, I only want to know the procedue in fasterase, where can i get the password that it needed.
I use this command to repaire IBM HD. no need other function, only erase , need the fastest speed.
 Post subject:
PostPosted: December 16th, 2004, 1:53
Hello huayuliang,
I am sure it is frustrating, but guru answered your question exactly,
do some searching and you will find some flow diagrams on how security
is treated in hard disk drives then you will see how mhdd does fasterase.
This function is not by program mhdd but mhdd using an ATA feature.
 Post subject:
PostPosted: December 16th, 2004, 6:08
thanks!!
But I can't understand why need type USER password during use the "fasterase".
why? I think its function is erase all data of HDD, the "erase" didn't need password. and my HDD hasn't be set any password.
 Post subject:
PostPosted: December 16th, 2004, 7:14
huayuliang wrote:
thanks!!
ATA set the standard and it sets the procedures, when you know them
you will understand them.
You must find some IBM data sheets :
Here is an example :
User Password Lost ??
LEVEL ? High
DO :  Unlock CMD with Master Password
RESULT : Normal operation
LEVEL ? Maximum
DO : Erase Prepare Command
DO : Erase Unit Command with Master Password
RESULT : Normal operation but data lost
Here is from a typical IBM datasheet :
If the User Password is forgotten and High level security is set,
the system user cannot access any data.
However the device can be unlocked using the Master Password.
If a system user forgets the User Password and Maximum security level is set, data access is impossible.
However the device can be unlocked using the Security Erase Unit command to unlock the device and erase all user data [b]with the Master Password.[/b]
Users browsing this forum: No registered users and 232 guests
