 Post subject: drive stop spinning BUT can access TERMINAL
PostPosted: August 20th, 2015, 9:52
hello,
I have a Seagate ST9500325AS that spin then stop after I hear noise (but not click or beep) but I can access Terminal even after the drive stop. Here the terminal output :
Rst 0x08M
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
F3 T>
F3 T>
F3 T>
F3 T>
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
opts = 00000000
RW Err = 84150180
F3 T>
F3 T>
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.123 msecs
F3 2>U
DiagError 00006008
Spin Error
Elapsed Time 16.840 secs
R/W Status 2 R/W Error 84150180
F3 2>
F3 2>
F3 2>/1
F3 1>N1
LED:000000CC FAddr:0026A86F
Could it be a FW and not Head issue?
 Post subject: Re: drive stop spinning BUT can access TERMINAL
PostPosted: August 20th, 2015, 10:21
http://acelaboratory.ru/forum/viewtopic ... 4d1#p29308
PostPosted: August 20th, 2015, 10:45
Thank you for your reply.
The solution proposed is when drive ID is read and drive continue spinning. In my case, drive stop spinning but I can access terminal :shock:
PostPosted: August 20th, 2015, 10:52
Heads....
+ probably surface.
PostPosted: August 20th, 2015, 11:34
pepe wrote:
Heads....
+ probably surface.
+1 heads + surface
get ready for more than 1 donor
RAID/Server Recovery
PostPosted: August 20th, 2015, 11:39
sorry didn't noticed, i thought that you manually stop the spinning by /2Z command
sosrecup wrote:
F3 T>/2
F3 2>Z
Spin Down Complete
PostPosted: August 20th, 2015, 13:09
As I had access to terminal, I tied to stop then start the drive by Terminal command which worked for STOP but not for START :(
I think it's more likely a head issue.
PostPosted: August 20th, 2015, 14:17
agreed
Users browsing this forum: No registered users and 195 guests
