 Post subject: WD15EADS-22P8B0 - can't format
PostPosted: September 18th, 2015, 17:21
Hello, I have a rather unusual problem because the patient WD15EADS-22P8B0 despite the fact that the test heads are SA and UA shows the efficiency of all six heads does not want format the user area. I would add that format stops in the area of the LBA 13000000 computer freezes and the end of the format. What wrong?
I can also run selfscan/ARCO test's. Any suggestions?
Log:
Test heads in User Area
2015-09-18 17:13:06: The drive WDC WD15EADS-22P8B0 SN: WD-WMAVU3820921 Disk size 2930277168 - 1500Gb FW:007700C7/01.00.A01
2015-09-18 17:13:08: P-list read successfully
2015-09-18 17:13:38: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 0 - Ok
2015-09-18 17:13:44: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 0 - Ok
2015-09-18 17:14:07: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 1 - Ok
2015-09-18 17:14:11: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 1 - Ok
2015-09-18 17:14:34: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 2 - Ok
2015-09-18 17:14:40: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 2 - Ok
2015-09-18 17:15:03: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 3 - Ok
2015-09-18 17:15:09: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 3 - Ok
2015-09-18 17:15:37: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 4 - Ok
2015-09-18 17:15:43: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 4 - Ok
2015-09-18 17:20:32: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 5 - Ok
2015-09-18 17:20:38: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 5 - Ok
Test heads in Service Area
2015-09-18 22:36:31: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 0 - Ok
2015-09-18 22:36:37: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 0 - Ok
2015-09-18 22:36:57: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 1 - Ok
2015-09-18 22:37:03: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 1 - Ok
2015-09-18 22:37:23: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 2 - Ok
2015-09-18 22:37:29: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 2 - Ok
2015-09-18 22:37:49: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 3 - Ok
2015-09-18 22:37:55: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 3 - Ok
2015-09-18 22:38:15: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 4 - Ok
2015-09-18 22:38:20: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 4 - Ok
2015-09-18 22:38:40: Çŕďčńü ňđĺęŕ ďî ăîëîâęĺ 5 - Ok
2015-09-18 22:38:46: ×ňĺíčĺ ňđĺęŕ ďî ăîëîâęĺ 5 - Ok
Selfscan procedure
2015-09-18 22:50:23: Number of the current test is set to 1
2015-09-18 22:50:24: Module IDE6 cleared
2015-09-18 22:50:24: Module IDFA cleared
2015-09-18 22:50:24: Module IDFB cleared
2015-09-18 22:50:24: Module IDFC cleared
2015-09-18 22:50:24: Module IDFD cleared
2015-09-18 22:50:25: Module IDFE cleared
2015-09-18 22:50:26: Module IDE0 cleared
2015-09-18 22:50:27: Module IDE1 cleared
2015-09-18 22:50:29: Module IDE2 cleared
2015-09-18 22:50:30: Module IDE3 cleared
2015-09-18 22:50:32: Module IDE4 cleared
2015-09-18 22:50:33: Module IDE5 cleared
2015-09-18 22:50:33: Error reading module E8, state -Module not in Dir???
2015-09-18 22:50:33: Error cleaning module IDE8
2015-09-18 22:50:33: Error reading module E9, state -Module not in Dir???
2015-09-18 22:50:33: Error cleaning module IDE9
2015-09-18 22:50:33: Error reading module EA, state -Module not in Dir???
2015-09-18 22:50:33: Error cleaning module IDEA
2015-09-18 22:50:33: Error reading module EB, state -Module not in Dir???
2015-09-18 22:50:33: Error cleaning module IDEB
2015-09-18 22:50:33: Error reading module EC, state -Module not in Dir???
2015-09-18 22:50:33: Error cleaning module IDEC
2015-09-18 22:50:33: Error reading module ED, state -Module not in Dir???
2015-09-18 22:50:33: Error cleaning module IDED
2015-09-18 22:50:33: RELO-List is cleared
2015-09-18 22:50:34: P-List is cleared
2015-09-18 22:50:35: G-List is cleared
2015-09-18 22:50:35: T-List is cleared
2015-09-18 22:50:35: Translator cleared
2015-09-18 22:50:36: SelfScan started
2015-09-18 22:51:13: Îřčáęŕ: Head: 1 Track: -189 (0xFFFFFF43) Err: BG_PST_UNABLE_TO_LOAD_PTM
ARCO 47 Test
2015-09-18 01:20:22: Ęîä ďđîčçâîäčňĺë˙ ăîëîâîę - A
2015-09-18 01:20:22: Ęîä ďđîčçâîäčňĺë˙ ďëŕńňčí - K
2015-09-18 01:20:40: ARCO Code successfully loaded into RAM
2015-09-18 01:20:40: ARCO Data successfully loaded into RAM
2015-09-18 01:20:40: Error starting calibrator test Full Arco, state - BE01
PCB: 2060-771640-003 REV P1
PCB Stricker: 2061-771640-M03-AA
MCU: 88i9045-TJF2
FLASH: PM25LD020
Ps. I using WDMARVEL 7A Beta HDD repair tool (full version)
sorry for my english, because am using google translator.
 Post subject: Re: WD15EADS-22P8B0 - can't format
PostPosted: September 19th, 2015, 13:39
Most likely scratch on the surface.
PostPosted: September 19th, 2015, 13:49
Have you tried regenerate translator ?
PostPosted: September 19th, 2015, 18:42
Yes, i do. nothing was change. Remind you also that I can not run the procedure selfscan.
PostPosted: September 21st, 2015, 16:31
Ehh, HDD works fine, the problem was power connected to the drive. I'm sorry for the confusion.
Users browsing this forum: No registered users and 265 guests
