 Post subject: hELP NEED DATA
PostPosted: October 20th, 2015, 2:10
MODEL IS SEGATE 7200.4 (320GB ) NEED DATA
 Post subject: Re: hELP NEED DATA
PostPosted: October 20th, 2015, 3:29
What tools do you have at your disposal?
You should image that drive with a Hardware imager.
ACELab partner
PostPosted: October 20th, 2015, 3:54
Try testing a few different locations of the drive.
If you can't read anything beyond the first red sector it's probably a translator issue. If you get some green blocks beyond the first red sector most likely 1 or more bad heads.
Web: https://www.day1data.de
PostPosted: October 20th, 2015, 4:25
ANY TERMINAL COMMAND :| :| :| I USE SEGATE F3 TOOL
PostPosted: October 20th, 2015, 15:11
You can find a list of Seagate Terminal Commands here, but before you start messing around with the translator, you should really do what was suggested and see if you can read any higher sector ranges. It's important to know if you're dealing with a translator issue or just bad sectors.
PostPosted: October 21st, 2015, 2:08
considering hard disk is very OLD , this type of ignorant experimentation may ruin data forever.
Users browsing this forum: No registered users and 42 guests
