 Post subject: Help with read of Grenada with surface scratches
PostPosted: October 19th, 2015, 7:05
Hello Guys.
I'm working with a Grenada with surface scratch.
There are four heads, H0 is bad and his surface too.
I did all process associated of the head, change, clean, isolations, reconfigure... you know!
But there is a problem, the hdd isn't full reading...
When I start/power on: it read servo marks, it read ID, doesn't click any time, send ready, disk stay spinning don't stop, and terminal is freeze.
The ID is incompelte, I have: Model; PN; Serial: (Size "wrong")...
inside terminal:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005[LBA=0x000042F9][LBA=0x000042F9]ooooMMMoMoooooooooooooooooooooooooooooooooooMMMMMFMFFFFFMMMMMMFMF
RECOV Servo Op=0155 Resp=0005[LBA=0x00066E3B]
RECOV Servo Op=0055 Resp=0005[LBA=0x00028F1D][LBA=0x00028F1D]ooooMMMoMoooooooooooooooooooooooooooooooooooMMMMMFMFFFFFMMMMMMFMF
RECOV Servo Op=0155 Resp=0005[LBA=0x0008BA5F][LBA=0x0008BB7B][LBA=0x0008BB7B]ooooMMMoMoooo[LBA=0x0008BB7C][LBA=0x0008BB7C]ooooMMMoMoooooooooooooooooooooooooooooooooooMMMMMFMFFFFFMMMMMMFMF
SimError - Remaining in BootFW
Perform a double download without a power cycle
I already tested other position of map, always is the same behavior and same terminal log.
Do you have some idea? And if you need more information, tell me!
I need to read the others surfaces.
Best regards.
 Post subject: Re: Help with read of Grenada with surface scratches
PostPosted: October 19th, 2015, 16:22
The terminal output indicates the PCB is not native.
Unless you are shorting read channels while the drive powers on??
Web: https://www.day1data.de
PostPosted: October 19th, 2015, 20:43
I'm still trying to figure out why you're bothering... Grenadas are a nightmare. When I see scratches on platter, I call it quits. Attempting that is a good way to waste your life away. It's a hamster wheel.
PostPosted: October 20th, 2015, 4:01
True that.
Has anyone found a pattern yet to matching donors for the Grenada "DM" drives?
I find even if you get the perfect donor and do a head swap you just end up with servo errors again. I have had a few successes but I find these drives the worst for head swaps that I have come across so far.
PostPosted: October 20th, 2015, 4:41
Yes, Grenadas are difficult and they need special treatment.
However, we have found a way to match donor heads for them, it only takes 4 minutes.
PostPosted: October 20th, 2015, 8:23
I already checked your serial number, the PCB is native.
Yes, I already tried, but I didn't have successful... I will try this more.
Could you tell me how in PM?
Thanks to all.
PostPosted: October 20th, 2015, 13:18
I agree.
PostPosted: October 20th, 2015, 13:28
Yes, agree.
Donor matching is not the issue for us with these drives, but they mostly tend to have media issues (platter scratches) on one or more platter surface which can be troublesome :-(
PostPosted: October 20th, 2015, 13:34
pcimage wrote:
Yes, agree.
Yes, it's not compatibility as much as the fact that they just tend to keep killing heads over and over. I don't how many I've done where you can change the heads over and over and each time it'll ID once, barely read data for a couple sectors and then just die again. I really hate these drives.
PostPosted: October 20th, 2015, 13:50
data-medics wrote:
You should physically remove faulty head(s) and read alive heads first. When good heads are done - then return and play with problem heads.
I used your way early when I can't start drive with absent head. But I didn't use different sets of heads - I just changed faulty head on original set of heads.
PostPosted: October 21st, 2015, 4:20
This is pretty much the idea. We don't have technique to physically remove the problem head and then replace it, but we bend them, and then bend them back in place.
PostPosted: October 21st, 2015, 6:11
Yes, agree.
May you tell me how? PM
data-medics wrote:
pcimage wrote:
Yes, agree.
I know this, but there are process very good to stop the broken heads and stop more scratch...
Guys about the post, the problem is not the head ok!
Nice, I really would like to know how to find a compatible head.... this really would be very good!
But my problem is other.
Look
I have a drive working, it read servo marks, sent me ID full (isn't Id of pcb... please!)
The problem is: when hdd finish starts process, it freeze, I can't use terminal to solve problems and access the S.A... maybe it doesn't read overlay but I'm not sure!
Boot 0x40M
Spin Up
Somebody had this problem? know how to solve it?
Best regards!
PostPosted: October 21st, 2015, 14:15
Did you try to short read channel and get access to terminal?
PostPosted: October 21st, 2015, 16:45
+1 and you need to find the correct moment to do so
PostPosted: October 22nd, 2015, 5:53
Yes.
I tryed many times, but I can try more,...
But until now, no results.
